Question: odeplots in an Explore command
Dear Maple users
Sometimes I use the Explore command in order to watch how plots containing parameters change when the parameters are changed via sliders. I tried to do the same with an odeplot. I can make it work, but I cannot do it the same way as I use to do with ordinary plots: I like to define the plot outside the Explore command, because those Explore commands can be quite cluttered and hard to overview. It is not that bad in my attached example below. Sometimes I have display commands handling several plots ...
In the attached file I show first how it works when the odeplot is inside the Explore command, but when I later move it outside, it won't work. Why this difference between ordinary plots and odeplots? Or maybe there is a workaround to make it work having the odeplot command outside ...
Regards,
Erik
odeplots_in_an_Explore_command.mw
