Question: procedure using for loop and add
I have written a procedure in which the content is written as either for loop or add commands. Since this procedure need to be evaluated around 1-1.5 lakhs times during iteration (running an iterative method) I need to know which of the two procedure will consume less memory. The whole calculation takes 4 gb. So i am trying to optimize the code. Thank you.
procedure_new.mw
