Question: Random number generators and memory
I tried three commands for uniform random distribution. The memory used by sequence created by Generate(distribution(Uniform(0, 1))) is very high. But this is the command which can bring randomness while doing metropolis algorithm. The other two commands consume very less memory but cannot bring randomness. I need the one which can inject randomness and at the same time uses less memory. Thank you.
DISTRIBUTION.mw
