Question: Random walk plot
I am really not good at writing the code. The code was from the book (Stochastic process with maple).
It does not seem to generate the different plots when I run the code.
Also the last added code was from the book but it shows error.
Thank you for the help in advance. (My English also is not good.)
with(stats)
with(plots)
RandWalk := proc (N, p, q, sa, sb, M) local A, B, r, PA, PC, PB, state, step, path; A := -N; B := N; r := 1-p-q; PA := empirical[0., sa, 1-sa]; PC := empirical[q, r, p]; PB := empirical[1-sb, sb, 0.]; state := 0; path := state; to M do if A < state and state < B then step := trunc(stats[random, PC](1))-2 elif state = A then step := trunc(stats[random, PA](1))-2 elif state = B then step := trunc(stats[random, PB](1))-2 end if; state := state+step; path := path, state end do; plots[pointplot]([seq([i, path[i]], i = 1 .. nops([path]))], axes = BOXED) end proc
RandWalk(3, .5, .5, .8, .8, 20)
plots[display]([seq(RandomWalk(10, .45, .5, .8, 300), k = 1 .. 4)], insequence = true); plots[display](%)
Error, (in plots:-display) cannot make plot structure from object with name RandomWalk
Download randomWalk.mw
with(stats)
with(plots)
