Question: uses function with the Physics package
When I apply the uses function with the Physics package in a procedure, the commands in this package are not restricted to the inside of the procedure, but are applied globally. See the example below:
gds := proc(LL, qi, t)
 local ta,i;
uses Physics;
ta := sec(diff(diff(LL, diff(qi[i](t), t)), t), i = 1 .. nops(qi));
RETURN(ta) end:
sxy := diff(x(t), t)^2 + diff(y(t), t)^2:
gds(sxy, [x, y], t);
Error, (in Physics:-diff) name expected for external function
On the other hand, when I apply the uses function with the LinearAlgebra package in a procedure, the commands in this package are restricted to the inside of the procedure only.
dst:=proc(MM)
local DA;
uses LinearAlgebra;
DA:=Determinant(MM);
RETURN(DA) end:
dst(<<1 | 2>, <3 | 4>>);
                  -2
Determinant(<<1 | 2>, <3 | 4>>);
                         Determinant(Matrix(2, 2, [[1, 2], [3, 4]]))
This could be a bug in Maple 2019?
