Question: Combining and converting units
  Note: To enter units, I used the unit key (blue) in the Units palette.
  When I use the combine and simplify functions to manipulate temperature units, Maple returns a wrong answer, as we can see below;
combine(20*Unit(Unit('Celsius'))+30*Unit('K'), units)
50*Units:-Unit(K)
simplify(20*Unit(Unit('Celsius'))+30*Unit('K'))
50*Units:-Unit(K)
  The quantity 20 Celsius is not converted correctly. However, for other types of dimensions, the combine and simplify functions work correctly.
combine(10*Unit('m')+120*Unit('cm')+200*Unit('ft'), units)
(1804/25)*Units:-Unit(m)
simplify(10*Unit('m')+120*Unit('cm')+200*Unit('ft'))
Another strange thing happens with the convert function, with temperature units. When we use the same source unit, the convert function deletes the unit, leaving only the quantity.
convert(30*Unit('K'), temperature, Unit('K'))
30
 I do not understand why this occurs.
convert(10*Unit('m'), units, Unit('m'))
10*Units:-Unit(m)
Oliveira
Download Matching_units.mw
