Question: Possible Bug in the StringTools "Has" command
I have specified the problem in the red comments of the worksheet i am uploading:
with(FileTools):
currentdir("H:\\USB 1 BACKUP\\ESD-USB\\maple_library"):
["ArithmeticMean_Display_Definition.txt", "BinomialCoefficient_PadicOrder.txt", "Binomial_coefficent_p_adic_valuation_Display_Definition.txt", "CompareGeometricMean.txt", "CompareHarmonicMean.txt", "CompareMean.txt", "Compare_Arithmetic_Mean_Description.txt", "Compare_Mean_Description.txt", "ConsistencyCompareGeometricMean.txt", "ConsistencyCompareHarmonicMean.txt", "ConsistencyCompareMean.txt", "delta.txt", "delta_Display_Definition.txt", "digit_base_conversion.txt", "EulerProduct.txt", "GeometricMean_Display_Definition.txt", "HarmonicMean_Display_Definition.txt", "Mobius.txt", "MultiplicitySet.txt", "omega.txt", "p_adic_valuation.txt", "p_adic_valuation_Display_Definition.txt", "RationalParition.txt", "SquareFreeCount.txt", "WilsonTheoremLemma.txt", "WilsonTheoremLemma1_Display_Definition.txt", "WilsonTheoremLemma2_Display_Definition.txt", "WilsonTheoremLemma3_Display_Definition.txt"]
with(StringTools):
L := map(StringTools:-Has, FunctionList, "_Display_Definition"):
S[display] := {}:
for k to nops(L) do if L[k] = true then S[display] := `union`(S[display], {FunctionList[k]}) else S[procedure] := `union`(S[procedure], {FunctionList[k]}) end if end do;
for t to nops(S[display]) do read S[display][t] end do;
S[display]
{"p_adic_valuation.txt", "Compare_Mean_Description.txt", "delta_Display_Definition.txt", "digit_base_conversion.txt", "ArithmeticMean_Display_Definition.txt", "BinomialCoefficient_PadicOrder.txt", "Compare_Arithmetic_Mean_Description.txt", "GeometricMean_Display_Definition.txt", "HarmonicMean_Display_Definition.txt", "p_adic_valuation_Display_Definition.txt", "WilsonTheoremLemma1_Display_Definition.txt", "WilsonTheoremLemma2_Display_Definition.txt", "WilsonTheoremLemma3_Display_Definition.txt", "Binomial_coefficent_p_adic_valuation_Display_Definition.txt"}
read S[display][5]
`The Arithmetic Mean for the multiset:`
[a[j]][j = 1 .. n]
mu[A] = (sum(a[j], j = 1 .. n))/n
read S[display][7]
`CompareArithmeticMean(L,N) will return output informing you of what percentage of N random`
`natural number multisets of the same length as the multiset L and same range=[min(L),max(L)]`
`have a lower arithmetic mean than L, equal to L, and greater than L.`
Download possible_string_tools_bug.mw
