Question: Solve a System of Equations With an Unknowns of f(x)
I am trying to plot generator reactive output (Q) over a range of generator power output (P) with field current (Ifldc) and terminal voltage (Et) constant using “solve”. The system of equations includes an interpolating fiction Ifld(el).
I’m looking for some help as to how to configure a solution. Attached are a few of my failed attempts.
The upload of my file deleats the "solve" fo my first try it is:
MvaGen := 1354; PfGen := .935; KvGen := 24
           Xd__u := 1.89 - Synchronous reactance of d-axis, Unsatuarted
              Xq__u := 1.80 - Synchronous reactance of q-axis, Unsatuarted
              X__l := .26   - leakage reactance d or q-axis``
            Ifld__base := 3114
Open Ckt Sat Curve DS807-1a
     First col=Ifld amps
     Second col= el voltage behind leakage reactance
OC_SatDat := Matrix(16, 2, {(1, 1) = 0, (1, 2) = 0., (2, 1) = 655.6456, (2, 2) = .3422578, (3, 1) = 1009.961, (3, 2) = .5331404, (4, 1) = 1253.12, (4, 2) = .6492209, (5, 1) = 1562.724, (5, 2) = .8014143, (6, 1) = 1893.545, (6, 2) = .9329786, (7, 1) = 2201.68, (7, 2) = 1.033593, (8, 1) = 2487.276, (8, 2) = 1.108416, (9, 1) = 2793.943, (9, 2) = 1.157452, (10, 1) = 3122.338, (10, 2) = 1.203911, (11, 1) = 3690.959, (11, 2) = 1.263294, (12, 1) = 4259.141, (12, 2) = 1.307202, (13, 1) = 4827.028, (13, 2) = 1.340795, (14, 1) = 5351.085, (14, 2) = 1.366646, (15, 1) = 5787.775, (15, 2) = 1.387329, (16, 1) = 6224.391, (16, 2) = 1.405433})
  ido := It*sin(theta+delta)
Plot OC saturation with field current in pu
with(LinearAlgebra)
with(ArrayTools)
with(plots)
      OC_Sat_Ifld_pu := Column(OC_SatDat, [1])/Ifld__base
         OC_Sat := Concatenate(2, Column(OC_SatDat, [2]), OC_Sat_Ifld_pu)
iterpolate values of field current vs el from OC sat curve
                                    pts_el := Column(OC_Sat, [1]); pts_Ifldpu := Column(OC_Sat, [2])
                         Ifield as a function of el  ->  Ifld := LinearInterpolation(pts_el, pts_Ifldpu)
Solve for Q with
P = .935; Iflc := 1.88; Et := 1.0
TRY1
 Eq1 := Ir = P/Et; Eq2 := Ix = Q/Et    Eq3 := It*sqrt(Ir^2+Ix^2)     Eq4:=theta = arctan(Q, P)
    Eq5 := el = abs(Et+X__l*(Ix+I*Ir))      Eq6 := `ΨAG__d` = Xad__u*Ifld(el)   Eq7:=K__ds = el/`ΨAG__d`
NULL Eq8 := Xd__s = K__ds*Xad__u+X__l   Eq9 := `ΨAG__q` = Xaq__u*Ifld(el)    Eq10 := K__qs = el/`ΨAG__q`
   Eq11 := Xq__s = X__l+K__qs(el)*Xaq__u      Eq12 := Eq = Et+Xq__s(el)*(Q/Et+I*P/Et)
NULLNULL
Eq13 := delta = argument(Eq)        Eq14 := eqo = Et*cos(delta)    Eq15 := ido = It*sin(theta+delta)
Eq16 := EI = Xd__s*Iflec; Eq17 := EI = Ido*Xd__s+eqo
syst := {E15, Eq1, Eq10, Eq11, Eq12, Eq13, Eq14, Eq16, Eq17, Eq2, Eq3, Eq4, Eq5, Eq6, Eq7, Eq8, Eq9}
solve(sys, {Eq, Ir, It, Ix, K__ds, K__qs, Q, Xd__s, Xq__s, el, eqo, ido, theta, `ΨAG__d`, `ΨAG__q`})
Warning, solving for expressions other than names or functions is not recommended.
TRY 2
`` Ix := proc (Q) options operator, arrow; Q/Et end proc   It := proc (Q) options operator, arrow; sqrt(Ir^2+Ix^2) end proc     theta := proc (Q) options operator, arrow; arctan(Q, P) end proc
 el := proc (Q) options operator, arrow; abs(Et+X__l*(Ix(Q)+I*Ir)) end proc      `ΨAG__d` := proc (Q) options operator, arrow; Xad__u*Ifld(el(Q)) end proc   K__ds := proc (Q) options operator, arrow; el(Q)/`ΨAG__d`(el(Q)) end proc``
NULL Xd__s := proc (Q) options operator, arrow; X__l+K__ds(el(Q))*Xad__u end proc   `ΨAG__q` := proc (Q) options operator, arrow; Xaq__u*Ifld(el(Q)) end proc    K__qs := proc (Q) options operator, arrow; el(Q)/`ΨAG__q`(el(Q)) end proc
Xq__s := proc (Q) options operator, arrow; X__l+K__qs(Q)*Xaq__u end proc      Eq := proc (Q) options operator, arrow; Et+Xq__s(Q)*(Q/Et+I*P/Et) end proc
delta := proc (Q) options operator, arrow; argument(Eq(Q)) end proc        eqo := proc (Q) options operator, arrow; Et*cos(delta(Q)) end proc    ido := proc (Q) options operator, arrow; It*sin(theta(Q)+delta(Q)) end proc``
EI := proc (Q) options operator, arrow; Xd__s(Q)*Iflec end proc    EI := proc (Q) options operator, arrow; eqo(Q)+Xd__s(Q)*Ido(Q) end proc
solve(EI(Q) = eqo(Q)+Xd__s(Q)*Ido(Q), {Eq, Ir, It, Ix, K__ds, K__qs, Q, Xd__s, Xq__s, el, eqo, ido, theta, `ΨAG__d`, `ΨAG__q`})
{Eq = Eq, Ir = Ir, It = It, Ix = Ix, K__ds = K__ds, K__qs = K__qs, Q = Q, Xd__s = Xd__s, Xq__s = Xq__s, el = el, eqo = eqo, ido = ido, theta = theta, `ΨAG__d` = `ΨAG__d`, `ΨAG__q` = `ΨAG__q`}
TRY3
     "Eq20:=Ir=P/(Et):     Eq21:=Ix=Q->Q/(Et):"
Error, invalid operator parameter name
"Eq20:=Ir=P/Et: Eq21:=Ix=Q->Q/Et:"
Download Qcalc1.mw
