Question: VectorCalculus:-PositionVector: Component vs. coordinate (Help File)
I am little confused about the help file regarding the VectorCalculus:-PositionVector function.
In the help file the first argument "comps" is defined as
"list(algebraic); specify the components of the position Vector"
In spherical coordinates, the position vector is
r e_r
So, if the position vector to be entered is given in terms of the components (in spherical coordinates), the VectorCalculus:-PositionVector function should be called as
VectorCalculus:-PositionVector([r,0,0],spherical)
But this returns
[0,0,r]
(in the cartesian frame). This would make sense if r coordinates is r, theta coordinate is 0 and phi coordinate is 0.
However, if I call it as
VectorCalculus:-PositionVector([a,b,c],spherical)
Then I end up with
[a*sin(b)*cos(c),a*sin(b)*sin(c),a*cos(b)]
Thus, the "components" given in PositionVector are not the components but the coordinates r=a, theta=b, and phi=c.
Am I missing something here or the help file is misleading?
I appriciate your help.
Thanks a lot.
