Question: Assume with subindexed variables (with/without Physics package)
I was trying to simplify an expression using assume. However, I ended up with very long evaluation time and got an error: "Error, (in type/complex) too many levels of recursion". Here is the case:
Consider the following code:
restart:with(Physics):
simplify(csgn(a-b),assume=[a::real,b::real, a>0,b>0,a>b])
this gives 1 as expected.
However, if I run the following code:
simplify(csgn(a-b[2]),assume=[a::real,b[2]::real, a>0,b[2]>0,a>b[2]])
I get an error ""Error, (in type/complex) too many levels of recursion" after along evaluation. The last condition a>b[2] is causing the along evaluation time. Without it I get, of course, signum(a-b[2]), which is fine.
If I do these tests without Physics package loaded, I get the result 1 immediately in both cases without any problem. So, something in Physics package is causing this problem.
What is the problem? and how can I resolve this issue?
Thank you in advance.
