Question: procedure in ribbonplot
Hello people in Mapleprimes,
I haven't written in this site for a long time.
I have a question in the below program, which is to write ribbons.
For the implementation of this program,
I wrote this.
ribbonplot5([cos, sin, cos + sin], -Pi .. Pi,numpoints=20);
In the part of pattern matching, as -Pi .. Pi above is a range, so it is OK.
But, when I changed this part to x=-Pi..Pi, an error message appears.
ribbonplot5([cos, sin, cos + sin],x=-Pi .. Pi,numpoints=20);
brings error messages:
"Warning, unable to evaluate the function to numeric values in the region; see the plotting command's help page to ensure the calling sequence is correct"
In the code of ribbonplot5,  x=-Pi..Pi which is the type of name=range shoud satisfy the pattern matching, as I wrote in the first part of the program as
ribbonplot5 := proc(Flist, r1::{range,name=range})
I cannot know why the part of the program:
" else
       newFlist := map(unapply, Flist, lhs(r1));
     opts := ['labels'=[lhs(r1), " "," "],
                 args[3 .. nargs]];
    ribbonplot5(newFlist,rhs(r1),op(opts)):
wouldn't work well.
I wish I could get an answer to this.
Thanks in advance.
This is a program in maple9 Advanced Programming Gude p. 253
graphic_ribbonplot.mw
extend := proc(f)
     local x, y;
     unapply(f(x), x, y);
p:=x->cos(2*x):
q:=extend(p);
     local i, m, p, n, opts,newFlist;
     opts := [args[3 .. nargs]];
     if type(r1, range) then
         if not hasoption(opts, 'numpoints', 'n', 'opts')
         then n := 25
         end if;
         m := nops(Flist);
         p := seq(plot3d(extend(Flist[i]), r1, (i-1) .. i,
                                  grid=[n, 2], op(opts)),
                       i = 1 .. m):
         plots[display](p):
     else
                 args[3 .. nargs]];
   end if:
