Question: Surface fit and Lowess
Colleagues, help me please. There is a 256 by 256 matrix in the form of a histogram or heat map.
I want to smooth this histogram and get a surface function.
I used Lowess.
However, there is a problem. the resulting function f (x,y) of the surface is calculated for a long time and it is not possible to use it in NonLinearfit. My NonLinearFit does not give a result. I try to use this function as  A * f(x,y) where A is parameter/
And my idea is to use this function as a template when approximating new poorer matrices. like copulas
What should I do?
