Question: Hide command prevents plot from moving in MapleFlow2022
Using the hide command after displaying a plot in MapleFlow2022 prevents that plot from being moved.
If you create another plot, then both plots are movable until you use the hide command again, at which point you need to create another plot to allow plots to be positioned.
