Question: How do I put variables from a maple worksheet into a python script and the output from there back into the worksheet?
I'm not sure if this can even be done, but if it's possible, how do I do it:
I have a python script called "Blue.py", the path should simply be "Blue.py", since my worksheet and the python script are saved in the same place.
I want to somehow import two arrays and an equation from maple to said python script, use them in a procedure there, and then import the output of said procedure, a 2d array, backwards to maple.
I don't really care what format the equation and the arrays take in python (the current version assumes types "np.array" for the arrays and type procedure for the equation, but I can always adjust it), but the type of the output of Blue.py should be of the form 2d Array (for example [[0,1],[8,-2],[3,3]] ).
Is it possible to shuffle input between maple worksheets and python scripts like that, and if so, how?
