Question: Numerical solution of the boundary value problem for the ODE
Hello. There is some system of differential equations with respect to the unknowns u1(x), u2(x), u3(x) with boundary conditions. Solved numerically using the dsolve command.
Is it possible to build a graph of a function of the form W=a*u1(x)+b*u2(x)+c*u3(x) based on this solution?
Thank you for your answers.
