Question: How can I create a plot from a function defined using fsolve
I'm using Maple 2022.  I'm using fsolve to solve for values of 3 variables and I've created a function that looks like
solution := (TtT, FtT) -> fsolve({eq1, eq2, eq3},{Y,P,PY},{Y=0..100,P=0..100,PY=0..100})
this works fine, giving answers like
solution(1, 0.5);
    {P = 0.1813175442, PY = 0.1593412279, Y = 0.4393982627}
I'd like to plot Y vs TtT at a fixed FtT of 0.5 so I defined a second function
YFtpt5 := TtT -> solution(TtT, 0.5)[3]
this also works fine, giving
YFtpt5(10);
                       Y = 0.02320766980
so I try to plot it with a range variable like this
with plots:
plot(YFtpt5,0.01..10)
but this gives the error
plot(YFtpt5, 0.01 .. 10);
Warning, unable to evaluate the function to numeric values in the region; see the plotting command's help page to ensure the calling sequence is correct
It draws axis but no plot.  I've evaluated the function at 0.01,10, and a number of points in between and everything I've tried gives a numeric answer.  Is it because the answer is "Y=0.43"  or something else.
