Question: Can anyone integrate dsolve/numeric with NLPSolve in evalhf format?
In a recent question/conversation, I had discussed integrating dsolve/numeric-based codes with NLPsolve at
https://www.mapleprimes.com/questions/236494-Inconsistent-Behavior-With-Dsolvenumeric-And-NLPSolve-sqp
@acer was able to help resolve the issue by calling NLPSolve with higher optimality tolerance.
I am starting a new question/post to show the need for evalhf as the previous post takes too long to load.
Code is attached for the same.
currentdir();
"C:\Users\Venkat\OneDrive - The University of Texas at Austin\Documents\trial\Learnningsqpoptim"
Test code written by Dr. Venkat Subramanian at UT Austin, 05/31/2023 and has been updated multiple times. This code uses CVP approach (piecwise constant) to perform optimal control. NLPSolve combination with RK2 approach to integrate ODEs (constant step size) works well for this problem. But dsolve numeric based codes work (with optimality tolerance fix from acer), but cannot handle large values of nvar (optimization variables).
Digits:=15;
15
eqodes:=[diff(ca(t),t)=-(u+u^2/2)*1.0*ca(t),diff(cb(t),t)=1.0*u*ca(t)-0.1*cb(t)];
[diff(ca(t), t) = -1.0*(u+(1/2)*u^2)*ca(t), diff(cb(t), t) = 1.0*u*ca(t)-.1*cb(t)]
soln:=dsolve({op(eqodes),ca(0)=alpha,cb(0)=beta},type=numeric,'parameters'=[alpha,beta,u],savebinary=true):
Note that Vector or Array form can be used for RK2h to implement the procedure for any number of variables/ODEs. But the challenge will be when implicit methods are used to integrate ODEs/DAEs and running them in evalhf form (this can be done with Gauss elimination type linear solver, but this will be limited to small number of ODEs/DAEs say 200 or so).
RK2h:=proc(NN,u,dt,y0::Vector(datatype=float[8]))#this procedure can be made efficient in vector form
local j,c1mid,c2mid,c10,c20,c1,c2;
option hfloat;
c10:=y0[1];c20:=y0[2];
for j from 1 to NN do
  c1mid:=c10+dt/NN*(-(u+u^2/2)*c10):
  c2mid:=c20+dt/NN*(u*c10)-0.1*dt/NN*c20:
  c1:=c10/2+c1mid/2+dt/NN/2*(-(u+u^2/2)*c1mid):
  c2:=c20/2+c2mid/2+dt/NN/2*(u*c1mid)-0.1*dt/NN/2*c2mid:
  c10:=c1:c20:=c2:
  od:
y0[1]:=c10:y0[2]:=c20:
soln('parameters'=[1,0,0.1]);soln(0.1);
[alpha = 1., beta = 0., u = .1]
[t = .1, ca(t) = HFloat(0.9895549324188543), cb(t) = HFloat(0.009898024276129616)]
ssdsolve:=proc(x)
interface(warnlevel=0):
#if  type(x,Vector)#if type is not needed for this problem, might be needed for other problems
#then
local z1,n1,i,c10,c20,dt,u;
global soln,nvar;
dt:=evalf(1.0/nvar):
c10:=1.0:c20:=0.0:
for i from 1 to nvar do
u:=x[i]:
soln('parameters'=[c10,c20,u]):
z1:=soln(dt):
c10:=subs(z1,ca(t)):c20:=subs(z1,cb(t)):
od:
-c20;
 #else 'procname'(args):
#end if:
ssRK2:=proc(x)#based on RK2
#interface(warnlevel=0):
option hfloat;
#if  type(x,Vector)
#then
local z1,n1,i,c10,c20,dt,u,NN,y0;
global nvar,RK2h;
y0:=Array(1..2,[1.0,0.0],datatype=float[8]):
#y0[1]:=1.0:y0[2]:=0.0:
NN:=256*2/nvar;#NN is hardcode based on the assumption that nvar will be a multiple of 2 <=256
u:=x[i]:
evalhf(RK2h(NN,u,dt,y0)):
od:
-y0[2];
#end if:
nvar:=2;
2
ic0:=Vector(nvar,[seq(0.1,i=1..nvar)],datatype=float):
bl := Vector(nvar,[seq(0.,i=1..nvar)],datatype=float):bu := Vector(nvar,[seq(5.,i=1..nvar)],datatype=float):
infolevel[Optimization]:=15;
15
CodeTools:-Usage(Optimization:-NLPSolve(nvar,evalhf(ssRK2),[],initialpoint=ic0,[bl,bu],optimalitytolerance=1e-6)):
NLPSolve: calling NLP solver
NLPSolve: using method=sqp
NLPSolve: number of problem variables 2
NLPSolve: number of nonlinear inequality constraints 0
NLPSolve: number of nonlinear equality constraints 0
NLPSolve: number of general linear constraints 0
NLPSolve: feasibility tolerance set to 0.1053671213e-7
NLPSolve: optimality tolerance set to 0.1e-5
NLPSolve: iteration limit set to 50
NLPSolve: infinite bound set to 0.10e21
NLPSolve: trying evalhf mode
NLPSolve: trying evalf mode
attemptsolution: number of major iterations taken 11
memory used=0.96MiB, alloc change=0 bytes, cpu time=16.00ms, real time=121.00ms, gc time=0ns
Calling the procedures based on RK2 with NLPSolve uses evalf for numerical gradient (fdiff). Providing a procedure for gradient solves this issue.
gradRK2 := proc (x,g)
option hfloat;
local base, i, xnew, del;
global nvar,ssRK2;
xnew:=Array(1..nvar,datatype=float[8]):
base := ssRK2(x);
for i to nvar do
xnew[i] := x[i]; end do;
for i to nvar do
del := max(1e-5,.1e-6*x[i]);
xnew[i] := xnew[i]+del;
g[i] := (ssRK2(xnew)-base)/del;
xnew[i] := xnew[i]-del;
end do;
CodeTools:-Usage(Optimization:-NLPSolve(nvar,evalhf(ssRK2),[],initialpoint=ic0,[bl,bu],objectivegradient=gradRK2,optimalitytolerance=1e-6)):
memory used=184.77KiB, alloc change=0 bytes, cpu time=31.00ms, real time=110.00ms, gc time=0ns
Significant saving in memory used is seen. CPU time is also less, which is more apparent at larger valeus of nvar.
dsolvenumeric based codes work for optimization, but evalf is invoked possibly for both the objective and gradient
CodeTools:-Usage(Optimization:-NLPSolve(nvar,(ssdsolve),[],initialpoint=ic0,[bl,bu],optimalitytolerance=1e-6)):
memory used=14.61MiB, alloc change=37.00MiB, cpu time=94.00ms, real time=213.00ms, gc time=46.88ms
Providing gradient procedure doesn't help with evalhf computaiton for dsolve/numeric based procedures.
graddsolve := proc (x,g)
global nvar,ssdsolve;
#xnew:=Vector(nvar,datatype=float[8]):
base := ssdsolve(x);
for i to nvar do
for i to nvar do
g[i] := (ssdsolve(xnew)-base)/del;
end do;
CodeTools:-Usage(Optimization:-NLPSolve(nvar,(ssdsolve),[],initialpoint=ic0,[bl,bu],objectivegradient=graddsolve,optimalitytolerance=1e-6)):
memory used=3.82MiB, alloc change=0 bytes, cpu time=31.00ms, real time=129.00ms, gc time=0ns
Calling both RK2 and dsolve based procedures again to check the values and computation meterics
s1RK2:=CodeTools:-Usage(Optimization:-NLPSolve(nvar,evalhf(ssRK2),[],initialpoint=ic0,[bl,bu],objectivegradient=gradRK2,optimalitytolerance=1e-6)):
memory used=185.09KiB, alloc change=0 bytes, cpu time=16.00ms, real time=95.00ms, gc time=0ns
s1dsolve:=CodeTools:-Usage(Optimization:-NLPSolve(nvar,ssdsolve,[],initialpoint=ic0,[bl,bu],objectivegradient=graddsolve,optimalitytolerance=1e-6)):
memory used=3.82MiB, alloc change=0 bytes, cpu time=31.00ms, real time=122.00ms, gc time=0ns
s1RK2[1];s1dsolve[1];
-.523900304316377463
-.523901163953022553
Next, a for loop is written to optimize for increasing values of nvar. One can see that evalhf is important for larger values of nvar. While dsolve/numeric is a superior code, not being able to use it in evalhf format is a significant weakness and should be addressed. Note that dsolve numeric evalutes procedures that are evaluated in evalhf or compiled form, so hopefully this is an easy fix.
infolevel[Optimization]:=0:
for j from 1 to 9 do
nvar:=2^(j-1):
soptRK[j]:=CodeTools:-Usage(Optimization:-NLPSolve(nvar,evalhf(ssRK2),[],initialpoint=ic0,[bl,bu],objectivegradient=gradRK2,optimalitytolerance=1e-6)):
print(2^(j-1),soptRK[j][1]);
od:
memory used=88.40KiB, alloc change=0 bytes, cpu time=0ns, real time=10.00ms, gc time=0ns
1, HFloat(-0.5008626988793192)
memory used=155.66KiB, alloc change=0 bytes, cpu time=16.00ms, real time=30.00ms, gc time=0ns
2, -.523900304316377463
memory used=175.36KiB, alloc change=0 bytes, cpu time=62.00ms, real time=80.00ms, gc time=0ns
4, -.535152497919956782
memory used=243.69KiB, alloc change=0 bytes, cpu time=156.00ms, real time=239.00ms, gc time=0ns
8, -.540546896131004706
memory used=260.09KiB, alloc change=0 bytes, cpu time=141.00ms, real time=260.00ms, gc time=0ns
16, -.542695734426874465
memory used=385.84KiB, alloc change=0 bytes, cpu time=313.00ms, real time=545.00ms, gc time=0ns
32, -.542932877726400531
memory used=0.65MiB, alloc change=0 bytes, cpu time=734.00ms, real time=1.18s, gc time=0ns
64, -.543011976841572652
memory used=1.24MiB, alloc change=0 bytes, cpu time=1.55s, real time=2.40s, gc time=0ns
128, -.543035276649319276
memory used=2.99MiB, alloc change=0 bytes, cpu time=3.45s, real time=5.92s, gc time=0ns
256, -.543041496228812814
for j from 1 to 6 do
nvar:=2^(j-1):
soptdsolve[j]:=CodeTools:-Usage(Optimization:-NLPSolve(nvar,evalf(ssdsolve),[],initialpoint=ic0,[bl,bu],objectivegradient=graddsolve,optimalitytolerance=1e-6)):
print(2^(j-1),soptdsolve[j][1]);
od:
memory used=0.66MiB, alloc change=0 bytes, cpu time=16.00ms, real time=11.00ms, gc time=0ns
1, HFloat(-0.5008631947224957)
memory used=3.79MiB, alloc change=0 bytes, cpu time=15.00ms, real time=52.00ms, gc time=0ns
2, -.523901163953022553
memory used=21.28MiB, alloc change=0 bytes, cpu time=78.00ms, real time=236.00ms, gc time=0ns
4, -.535153942647626391
memory used=144.82MiB, alloc change=-4.00MiB, cpu time=469.00ms, real time=1.60s, gc time=46.88ms
8, -.540549407239521607
memory used=347.30MiB, alloc change=16.00MiB, cpu time=1.27s, real time=3.45s, gc time=140.62ms
16, -.542699055038344258
memory used=1.33GiB, alloc change=-8.00MiB, cpu time=7.66s, real time=15.92s, gc time=750.00ms
32, -.542936165630524603
SS:=[seq(soptRK[j][1],j=1..9)];
[HFloat(-0.5008626988793192), -.523900304316377463, -.535152497919956782, -.540546896131004706, -.542695734426874465, -.542932877726400531, -.543011976841572652, -.543035276649319276, -.543041496228812814]
E1:=[seq(SS[i]-SS[i+1],i=1..nops(SS)-1)];
[HFloat(0.02303760543705824), 0.11252193603580e-1, 0.5394398211048e-2, 0.2148838295869e-2, 0.237143299527e-3, 0.79099115172e-4, 0.23299807746e-4, 0.6219579494e-5]
To get 6 Digits accuracy we need nvar = 256 which may not be attainable with dsolve/numeric approach unless we are able to call it evalhf format.
Download ImportanceofevalhfNLPSolve.mw
