Question: using arrows = curve gives error in DEplot. Any workaround?
After I switched to using arrows = curve in the call to DEtools:-DEplot I found errors in some calls.
Is there a workaround other than not using this option? As phase plot looks like better with this option. For now, I will remove this option.
Here is an example
ode:=diff(y(x),x)-1/(-x^2+1)^(1/2) = 0;
x_range:=-0.99 .. 0.99;
DEtools:-DEplot(ode,y(x),x =x_range,y = -1.6 .. 1.6,[y(0) = 0],arrows = 'curve')
Error, (in DEtools/DEplot/direction) cannot assign a complex value to a hardware float Array
But this works
DEtools:-DEplot(ode,y(x),x =x_range,y = -1.6 .. 1.6,[y(0) = 0])
I will report this to Maplesoft as it looks like a bug to me.
May be someone can find a workaround so I can use arrows = curve?
Maple 2023.2 on windows 10
diff(y(x), x)-1/(-x^2+1)^(1/2) = 0
-.99 .. .99
-.99 .. .99
Download detools_deplot_arrows_curve_problem_NOV_10_2023.mw
