Question: How to diplay lots of curves
Using Maple-18 on Window 11...
I have a set of curves in a Maple 'vector.' I want to plot them all on the same figure, but if call 'display' with the vector it makes separate plots for each one. I have to all it with each plot individual to get them on the same plot:
lc is a 'vector' of curves (I use 'vector' because I want to append and that doesn't work for 'list')
display(lc) -- plots a separate plot for each element of lc
display(lc[1], lc[2], lc[3],...) puts them all on one plot as needed, but as there will be a large numbe of curvesr it's extremely tedious.
It is a Huygens principle based simulation of diffraction.
estart; with(Physics); with(LinearAlgebra); with(VectorCalculus); with(Optimization); with(Statistics); with(ArrayTools); with(plots); with(plottools); with(Threads); with(MmaTranslator[Mma]), with(StringTools); with(CodeGeneration); with(ImageTools); with(ImageTools:-Draw); VectorCalculus:-`*`(Setup(mathematicalnotation = true), Setup(coordinatesystems = cartesian))
estart
[annulus, arc, arrow, circle, cone, cuboid, curve, cutin, cutout, cylinder, disk, dodecahedron, ellipse, ellipticArc, exportplot, extrude, getdata, hemisphere, hexahedron, homothety, hyperbola, icosahedron, importplot, line, octahedron, parallelepiped, pieslice, point, polygon, prism, project, rectangle, reflect, rotate, scale, sector, semitorus, sphere, stellate, tetrahedron, torus, transform, translate]
`Default differentiation variables for d_, D_ and dAlembertian are:`*{X = (x, y, z, t)}
`Systems of spacetime Coordinates are:`*{X = (x, y, z, t)}
radius := 1.0
1.0
alpha := sin((1/4)*Pi)
(1/2)*2^(1/2)
step := .2
.2
radius := 100.0
100.0
l1 := line([0, 0], [100, 100])
CURVES([[0., 0.], [100., 100.]])
loAng := 0.
0.
hiAng := (1/2)*Pi
(1/2)*Pi
c1 := arc([0, 0.], radius, loAng .. Pi, color = "red")
c2 := arc([step, 0.], -alpha*step+radius, loAng .. hiAng, color = "blue")
c3 := arc([2*step, 0.], -2*alpha*step+radius, loAng .. Pi, color = "purple")
c4 := arc([3*step, 0.], -3*alpha*step+radius, loAng .. Pi, color = "black")
plots[display](l1, c1, c2, c3, c4, view = [0. .. radius, 0 .. radius])
`cir≔arc`([x, 0.], radius-step, loAng .. hiAng, i, color = "red")
`cir≔arc`([x, 0.], 99.8, 0. .. (1/2)*Pi, i, color = "red")
xLimitWall := 500.0; nScatter := 20; step := xLimitWall/(nScatter+1); x := 0.; for i from 0 to nScatter do x := x+step; cir := arc([x, 0.], radius-step, 0 .. Pi, color = "red"); if i = 0 then lc := Vector([cir]) else i; cir; Append(lc, cir) end if end do; lc
xLimitWall := 500.0
nScatter := 20
step := 23.80952381
x := 0.
x := 23.80952381
cir := CURVES(Vector(4, {(1) = ` 200 x 2 `*Matrix, (2) = `Data Type: `*float[8], (3) = `Storage: `*rectangular, (4) = `Order: `*Fortran_order}), COLOUR(RGB, 1.00000000, 0., 0.))
x := 47.61904762
x := 71.42857143
x := 95.23809524
x := 119.0476190
x := 142.8571428
x := 166.6666666
x := 190.4761904
x := 214.2857142
x := 238.0952380
x := 261.9047618
x := 285.7142856
x := 309.5238094
x := 333.3333332
x := 357.1428570
x := 380.9523808
x := 404.7619046
x := 428.5714284
x := 452.3809522
x := 476.1904760
x := 499.9999998
Vector[column](%id = 4400555778)
lc[1]
CURVES(Matrix(%id = 4400554242), COLOUR(RGB, 1.00000000, 0., 0.))
lc(2)
lc
lc[1]
Download JFKWEdgeDifractionDirection.mwJFKWEdgeDifractionDirection.mwen.
