Question: how to call dsolve with _homogeneous, `class G` method?
Maple dsolve allows one to specify the algorithm to use to solve the ode. But sometimes it is very tricky to figure the syntax,
This ode
ode:=diff(y(x),x)*y(x)+a*x*y(x)+b*x^3=0;
DEtools:-odeadvisor(ode);
Gives
               [[_homogeneous, `class G`], _rational, [_Abel, `2nd type`, `class A`]]
I wanted now to call dsolve telling dsolve to use the first method above. But how? All the following syntax failed for me
sol:=dsolve(ode,['_homogeneous, `class G`']);
sol:=dsolve(ode,'[_homogeneous, `class G`]');
All return method not found .
I am sure I am using wrong syntax but do not know what the correct one should be.
infolevel[dsolve]:=5;
sol:=dsolve(ode);
gives
Methods for first order ODEs:
--- Trying classification methods ---
trying a quadrature
trying 1st order linear
trying Bernoulli
trying separable
trying inverse linear
trying homogeneous types:
trying homogeneous G
<- homogeneous successful
With long solution printed now OK.
When using just '[homogeneous]' it works
sol:=dsolve(ode,'[homogeneous]');
It gives same solution as default case.
What is the correct syntax to tell dsolve to use specific method [_homogeneous, `class G`] ? i.e. I need to add class G
The reason I ask is becuase Maple have different kind of homogeneous method as described here
Maple 2023.2.1 on windows 10
