Question: Plotting intersection point of two equations fails with symbolic solution
Hello everyone,
I successfully plotted the intersection point of two linear equations using a matrix-based approach. Still, I’m facing an issue when trying to achieve the same result using the second method — solving the system symbolically and plotting without matrices.
The Matrix-Based Approach (Working): I used the following steps to plot both equations and mark the intersection point (solution). However, when I switch to solving the system symbolically without matrices, I can plot the two lines, but I'm unable to plot the intersection point correctly.
It seems that the symbolic solution isn't being properly converted to a numeric form for pointplot, even though I’m using evalf.
Any help would be greatly appreciated!
Download Linear_System.mw
