Question: Lipschitz condition
I recently read something in another forum about solving a simple ordinary differential equation as an initial value problem (file attached). An unexpected solution behavior was interpreted there as a weakness of the software. However, upon closer inspection, the cause is different, and as a software novice, I cannot determine it myself.
Therefore, my question is:
Is there a way, using Maple, to check the Lipschitz condition in the neighborhood of the initial value before starting the solution of an explicit first-order system of differential equations as an initial value problem?
DGL_test.mw
