Question: Pixel Counting with Fractals
Below is the code found on this site for generating the mandelbrot set.
with(ImageTools):
MyMandel := proc(pt)
local i,z,c;
c := pt;
if abs(c) > 2 then
return 1;
else
z := c;
for i from 2 to 100 do
z := z^2 + c;
if abs(z) > 2 then
return i;
end if;  end do:
return 0;
end if; end proc;
GenerateComplex := proc(pts,X1,X2,Y1,Y2)
option evalhf;
local X::Vector, Y::Vector, f1::Vector, Z::Vector;
X := Vector(pts, i -> X1+(X2-X1)*(i-1)/(pts-1), datatype=float[8]):
Y := Vector(pts, i -> Y1+(Y2-Y1)*(i-1)/(pts-1), datatype=float[8]):
f1 := (i,j) -> X[j] + Y[i]*I:
Z := Matrix(pts,f1,datatype=complex[8]):
return Z:
Zc := GenerateComplex(400, -2, 1, -1.35, 1.35):
sol := LinearAlgebra[Map](MyMandel, Zc):
img := Create(sol):
View(FitIntensity(img));
Now what I would like to do is modify this a bit so that It will only turn pixels that stay below 2 (that is, absolute value below 2) after how many iterations I specify in the "for i from 2 to 100" part (where 100 is the amount of iterations) turn black and the rest are white.
I think this can somewhat be found by looking at the Matrix Zc and seeing where 0 (i think) occurs. If this is so can someone just confirm this?
Basically I'm trying to count the pixels that make up the Mandelbrot set to see what area comes out!
