Question: Using Simplex iteratively
Dear Maple friends,
I have the following problem: after solving LP1, I want to find the values of this solution. And with this solution, replacing in LP1--  I obtain a new LP problem  called LP2. I want to solve these steps  in an efficient way. I am still using Maple 10.
[ LP1: ]
Max  alpha
subject to
x1  +  x2 + x3                                +    alpha  >= 95
x1 + x2           +x4                         +    alpha  >= 85
x1        + x3  + x4                          + alpha  >= 80
     x2  + x3  + x4                           + alpha >= 55
              x1 +x2                              +alpha >= 50
              x1 + x3                             + alpha >= 50
              x1 + x4                             + alpha >= 50
              x2 + x3                             +alpha >= 50
              x2 + x4                             + alpha >= 50
              x3 + x4                             + alpha >= 50
             x1                                      + alpha >= 0
              x2                                      + alpha >=0
              x3                                      + alpha >=0
              x4                                        +alpha >=0
  x1 + x2+ x3 + x4                                         =100
x1        >=0
x2        >=0
x3        >=0
x4        >=0
[end of the problem]
Solving the previous problem,we obtain a solution of the kind:
alpha = 10
x3 = 23
x4 = 15
x1>=30
x2>=  25
x1+x2 =60
Replacing (the solution x3=25 and x4 = 15, x1+x2 =60 and simplifying) in the previous problem we obtain a new version of problem LP1
LP_2a
Minimize   alpha2
subject to
x1 + alpha2 >=40
x2+alpha2 >=15
x1+alpha2 >= 25
x1+alpha2 >=35
x2+ alpha2 >=25
x2 + alpha2>=35
x1+x2 =60
x1 >= 30
x2 >= 25
I can simplify even more to obtain
[SECOND PROBLEM]
LP2
Min  alpha2
subject to:
x1 + alpha1  >=40
x2 + alpha1 >=  35
x1+x2 =60
x1>=30
x2>=25
SOLUTION:  alpha2 = 7.5,  x1= 32.5,  x2= 27.5
The problem is:  Starting with LP1, how can I solve LP2 in an efficient way?. I will need to do this kind of "iterated" application of simplex, considering several steps: LP1, LP2..LP12, and several times. Then.. I dont want to do by hand.
Thanks in advance for advices,
Regards,
Jean-Jacques
