Question: External Calling: mat_mult-Example
Call me stupid but I still wasn't able to run the simple example in the maple help (see http://www.maplesoft.com/support/help/view.aspx?path=Define_external ) regarding calling external, precompiled Code (in my Case: c++).
Here's what I did: I went to Visual Studio Express 08 and stored in mat_mult.cpp the following:
#include "mat_mult.h"
#include <stdexcept>
using namespace std;
namespace MathFuncs
    void MyMathFuncs::mat_mult( double *A, double *B, double *C, int I, int J, int K ){
      int i, j, k;
      double t;
      for( i = 0; i < I; ++i ){
        for( k = 0; k < K; ++k ) {
          t = 0.0;
          for( j = 0; j < J; ++j ){
            t += A[i*J+j] * B[j*K+k];
          C[i*K+k] = t;
and the corresponding header-file: mat_mult.h
namespace MathFuncs
    class MyMathFuncs
    public:
        static __declspec(dllexport) void mat_mult( double *A, double *B, double *C, int I, int J, int K );
This went well and created a file "matrixmult.dll". Now I copied this file to my working directory.
As in the manual (see again http://www.maplesoft.com/support/help/view.aspx?path=Define_external ) I tried to load the mat_mult-Funktion with:
mat_mult := define_external('mat_mult', a::(ARRAY(1 .. i, 1 .. j, float[8])), b::(ARRAY(1 .. j, 1 .. k, float[8])), c::(ARRAY(1 .. i, 1 .. k, float[8])), i::(integer[4]), j::(integer[4]), k::(integer[4]), LIB = "matrixmult.dll");
This gives the error:
Error, external lookup of mat_mult: Given procedure not found.
(I also tried the same with 'MyMathFuncs::mat_mult' or 'MyMathFuncs.mat_mult' instead of 'mat_mult' but the same error.)
