Question: what is the Maple equivalent of Matlab's axis ([-inf inf -inf inf]) ?
matlab has the following command:
where the inf means (something like) "the largest value" and -inf "the smallest value". With this command, you can set the dimension of the axes without having to enter the actual values, which is then robust to changes in parameter values. This is most useful in situations where some of the values are to be fixed and others left to the simulation, say:
axis ([0 inf -inf 1])
What would be the Maple equivalent or workaround?
many thanks.
