Question: How use NPLSolve
Dear Experts,
I want to solve 2 workssheets with NPL Solve with Maple 12.
But how is it done? In worksheet 1 I always get this error. Unless I have solved this worksheet one err I can not continue wrking on worksheet two.
Thnaks for help
Walter
> with(Optimization); datax := [10, 15, 20, 25, 30, 45, 60, 90, 120, 150, 180]; datay := [428, 334.1, 280.7, 262.7, 242.4, 212.9, 182.2, 151, 130.5, 116.9, 109.5]; tau := 1;
  [ImportMPS, Interactive, LPSolve, LSSolve, Maximize, Minimize, NLPSolve,
    QPSolve]
> model := N1*exp(lambda1*(t-tau))+N2*exp(lambda2*(t-tau));
              N1 exp(lambda1 (t - 1)) + N2 exp(lambda2 (t - 1))
> residuals(N1,N2,lambda1,lambda2) := [sum( (datay[i]-eval(model,t=datax[i]))^(2), i=1..nops(datax))];
           (N1, N2, lambda1, lambda2) -> [
             nops(datax)                                         ]
                 )                                              2]
                /       (datay[i] - (eval(model, t = datax[i]))) ]
                i = 1                                            ]
> NLPSolve((428-N1*exp(9*lambda1)-N2*exp(9*lambda2))^2+(334.1-N1*exp(14*lambda1)-N2*exp(14*lambda2))^2+(280.7-N1*exp(19*lambda1)-N2*exp(19*lambda2))^2+(262.7-N1*exp(24*lambda1)-N2*exp(24*lambda2))^2+(242.4-N1*exp(29*lambda1)-N2*exp(29*lambda2))^2+(212.9-N1*exp(44*lambda1)-N2*exp(44*lambda2))^2+(182.2-N1*exp(59*lambda1)-N2*exp(59*lambda2))^2+(151-N1*exp(89*lambda1)-N2*exp(89*lambda2))^2+(130.5-N1*exp(119*lambda1)-N2*exp(119*lambda2))^2+(116.9-N1*exp(149*lambda1)-N2*exp(149*lambda2))^2+(109.5-N1*exp(179*lambda1)-N2*exp(179*lambda2))^2, initialpoint = {N1 = 1.122*10^3, N2 = 1.2830*10^3, lambda1 = -0.39e-1, lambda2 = -.326}, method = sqp);
 [439.485735349367132, [N1 = 257.198668654980508, N2 = 531.115292604514707,
   lambda1 = -0.00532918849969983132, lambda2 = -0.119870376119667720]]
> NLPSolve(residuals(N1, N2, lambda1, lambda2), initialpoint = {N1 = 1.122*10^3, N2 = 1.2830*10^3, lambda1 = -0.39e-1, lambda2 = -.326}, method = sqp);
Error, (in Optimization:-NLPSolve) objective function must be specified as a procedure or algebraic expression
> residuals(N1, N2, lambda1, lambda2);
         [                                             2
         [(428 - N1 exp(9 lambda1) - N2 exp(9 lambda2))
                                                               2
            + (334.1 - N1 exp(14 lambda1) - N2 exp(14 lambda2))
                                                               2
            + (280.7 - N1 exp(19 lambda1) - N2 exp(19 lambda2))
                                                               2
            + (262.7 - N1 exp(24 lambda1) - N2 exp(24 lambda2))
                                                               2
            + (242.4 - N1 exp(29 lambda1) - N2 exp(29 lambda2))
                                                               2
            + (212.9 - N1 exp(44 lambda1) - N2 exp(44 lambda2))
                                                               2
            + (182.2 - N1 exp(59 lambda1) - N2 exp(59 lambda2))
                                                             2
            + (151 - N1 exp(89 lambda1) - N2 exp(89 lambda2))
        2
            + (130.5 - N1 exp(119 lambda1) - N2 exp(119 lambda2))
        2
            + (116.9 - N1 exp(149 lambda1) - N2 exp(149 lambda2))
        2]
            + (109.5 - N1 exp(179 lambda1) - N2 exp(179 lambda2)) ]
