Question: Removing Components from Subsystems Library
When a user drags and drops a component from the pallette, a copy of the component is copied into the subsystem library located in the lower right of the screen.  This is handy if used again so that the user does not have to drill down into the pallettes repeatedly.  But, after a while the copies accumulate in the subsystems library, and it would be nice to selectively delete them if the user knows they will not be used again.  I have not found any way to delete the built in components copyied into the subsystem library.  I suppose it is childishly simple, but the operation eludes me.  Can someone show me how to do it?  Thanks.
Ratch
