Question: MapleSim 1.01 is now available
MapleSim 1.01, an all-platform maintenance update to MapleSim 1.0, is available to all users.
The MapleSim 1.01 update provides support for the MapleSim Connectivity Toolbox, as well as updates and improvements in usability, stability and performance. Even if you are not planning on using the Connectivity Toolbox, you should still install this update.
The automatic update facility should be available in the next day or so. From the Help menu in MapleSim, select Check for Updates.  If that option is dimmed, you can manually download the update from the the MapleSim 1.01 update page.
Eithne (Maplesoft)
