Question: Maintaining shading when exporting plot as EPS
All:
I am trying to export a shaded plot with the transparency set to approximately 0.5 so that the gridlines are visible under the shading.  I am exporting it as an EPS for viewing in Ghostscript and/or LaTex.  Here is a simple example.
pf:=plot(x,x=1..5, view=[0..5.5,0..5.5], gridlines=true, tickmarks=[5,5], thickness=2);
pfshading:=plot(x,x=1..5, view=[0..5.5,0..5.5], gridlines=true, tickmarks=[5,5], filled=true, color=COLOR(RGB,.7,.9,.7), transparency=.5);
display(pf,pfshading);
However, when I view it in Ghostscript and/or LaTex, the transparency disappears as if set to 0 and the gridlines are no longer visible underneath the shading.
Any ideas?  Thanks in advance.
Phil
