Question: changing variable in integral
I am trying to change the variable in an integral and I have two problems with it:
My first problem is that I can't get the integrand of the new integral with GetIntegrand when I use IntegrationTools[Change] :
a1:=Int(1/(2*A),x=-A..A);
D1:=IntegrationTools[Change](a1,x=20*log[10](u));
# It is ok, but I would like to get the new integrand:
IntegrationTools[GetIntegrand](D1);
# it doesn't work, because some parts of the new integrand are outside the integral and GetIntegrand can't handle this.
# Fortunately with PDEtools[dchange]  Maple can do it:
D2:=PDEtools[dchange](x=20*log[10](u),a1);
IntegrationTools[GetIntegrand](D2); # ok.
 My second problem is that when I use a constant (K) in the expression of the variable transformation, the Change can't handle it:
D1:=IntegrationTools[Change](a1,x=K*log[10](u))  assuming AndProp(K::realcons,K>1);
# it gives an error message.
Thanks you for your comment in advance.
