Question: nonlinear inequalilies
I'm trying to graph nonlinear systems of inequalities.  INEQUAL works only with linear systems.  Someone in this forum suggested IMPLICITPLOT with the option FILLED = TRUE, but this doesn't always give the desired results since that option only gives the area between the curve and the x-axis a solid color.  What I need is the power of OPTIONSFEASIBLE, OPTIONSEXCLUDED, OPTIONSOPEN, and OPTIONSCLOSED (options available with INEQUAL) that will work with nonlinear inequalities.
Alla
