Question: How to map a 2-D surface on a sphere?
Actually, I could just cut to the chase here...
I need to print out a 2-D ring and then attach that to a 3-D sphere.  The problem is that the 2-D ring will buckle as I attempt to attach the outer circumference of it to the sphere.
I started wondering if I could use Maple to help me visualize other shapes (which must be closed) and show me how much they would buckle as I mapped them onto a sphere.  I realize that I could probably use a CAD program to do this, but don't believe that the CAD programs available to me will allow me to describe the 2-D shapes parametrically (e.g. sinewave for 1/4 cycle, cosine, etc...)
Anyhow... if anybody has already solved this problem, I would appreciate pointers or tips to the solution.
Failing that, if anybody would care to point a complete Maple beginner at how to get started drawing 2-D shapes and then folding them around a 3-D sphere, that should be enough to get me started.
(There also exists the possibility that what I want to do is physically impossible, in which case I would simply like to know how "close" I can get to the ideal).
Thanks for any help.
--wpd
