Question: Pattern matching in a sequence of digits
This problem arised in a math forum.
I would like to check wether the consecutive digits of a given positive integer (n) are in the first 100000 digits of Pi.
For example the given integer (n) = 1592653 and this is in 3,1415926535897.... so the result is true.
I also would like to use this pattern matching for checking the type of a variable in a procedure:
myproc:=proc(n::mytype)
...end proc;
The procedure accepts n if n fullfils the condition above.
How to do it in Maple? How to define mytype?
