Question: HELP (URG)!!! PLEASE MAPLE 11
Please help me solve these two problems please past the code for maple 11.
2. For the function
f
(x) = exp(x) − 3x2,
(a) Use a Maple plot to show that there is a zero of the function in the interval [2
(b) Implement Newton’s method for this function with an initial guess of
should be set to loop for 100 times, but using an
, 4].x0 = 2.9. The programif ... then ... end if:
command stop the execution when
Newton’s method is given by
|f(xn)|  0.000001; this is called a stopping condition.
x
n+1 = xn −
f
(xn)
f
0(xn) , n = 0, 1, 2, 3, . . .
x0.
3. The Fibonacci Sequences are used in a number of areas of mathematics from the breeding of
rabbits to search schemes. The sequence is given by the recursive formulae
x
n+2 = xn+1 + xn
where
x1 = 1 and x2 = 1.
(a) Calculate the first five terms by hand, for example
x3 = x2 + x1 = 1 + 1 = 2.
(b) Write a small program using a loop to calculate and print out the first 20 values.
