Question: Newton's Method Question
I'm very confuse with this question:
- Find one root/zero of  2*x^5-5*x^4+3*x^3-3*x^2+x+2 using Newton's Method. If your polynomial is sadly lackaing in a root, subtract some constant value until the polynomial cuts the x-axis
- Produce four iterations of the Newton's Method. This will result in four successively accurateapproximations to one solution of p(x)=0
- For each iteration, report your beginning xn and the subsequent xn+1 value. For each run, also product a graph of p(x) and the graph of the newest Newton created tangent line
Please help me with that. Thank you
