Question: Plotting procedure solutions
A procedure named curve(x) in the attached worksheet solves several equations, each dependent on the solution to the previous equation.  The problem is that when I issue the plot command for a range of the dependent variable x, the equation result that gets plotted is not for the result of the solution to the last equation for P.  Specifically, I would like to issue the "plot(curve,0.0..0.5, <other format commands>);" and get a plot of k vs. P.  Currently the plot is of k vs. P_bar.  Your comments are appreciated.
View 4865_Procedure Results.mw on MapleNet or Download 4865_Procedure Results.mw
View file details
