Question: Populating a spreadsheet within a procedure
I have a procedure that contains a loop, solving a set of simultaneous equations for each increment of a known variable (k) and two unknown variables (beta and N_bar). What I would like to do is populate a Maple spreadsheet with the solution to each iteration of the loop, creating three columns of data for each iteration (k, beta, and N_bar). The attached worksheet will create the spreadsheet and loop through a set of equations, but I don't know if there is a way to populate the spreadsheet in the format desired. Thank you for your suggestions and help. View 4865_Populate_sheet.mw on MapleNet or Download 4865_Populate_sheet.mw
View file details
