Question: Menu command found in the manual, but not found in Maple
As per instructions at the bottom of page 217 of the user manual, I wish to alter the y-axis range of a 2D plot. The instructions say to right click the plot region. Select axes and then range, however, doing so allows one to select axes, but the menu item range is nowhere to be found in the menu as described by the manual. The menu only offers the choices of normal, boxed, framed, none, properties, labels, toggle gridlines, and set gridline properties.
