Question: ODE with maplets problem
Hello I'm new here and I need some help from you guys
I try to create a simple maplets to find the solution for ODE problems (first order only) But I keep getting the error message that saying
"expecting an ODE or a set or list of ODE's. Received ___"
here's mine:
> restart;
> with(Maplets[Elements]);
> with(DEtools);
> Count := proc () if Maplets:-Tools:-Get('CB1') = true then dsolve({Maplets:-Tools:-Get('TF1'), Maplets:-Tools:-Get('TF3')}, y(x)) else dsolve(Maplets:-Tools:-Get('TF3')) end if end proc;
proc()  ...  end;
> maplet := Maplet(Window('title' = "First ODE", 'menubar' = 'MB1', [
["Equation", TextField['TF3'](25), Button("Clear", SetOption('TF3' = ""))],
["Initial Condition", TextField['TF1'](), Button("Clear", SetOption('TF1' = ""))],
["Use initial condition?", CheckBox['CB1']('value' = 'false')], TextBox['TB1']('editable' = 'false', 3 .. 40),
[Button("dsolve", Evaluate('TB1' = "Count")), Button("OK", Shutdown(['TF3', 'TB1']))]]),
MenuBar['MB1'](Menu("File", MenuItem("Close", Action(RunDialog('C1')))),
Menu("Help", MenuItem("What Is This?", Action(RunDialog('H1'))))),
ConfirmDialog['C1']('question', "Is it ok?", 'onapprove' = Shutdown('true'), 'ondecline' = Shutdown('false'), 'oncancel' = Shutdown("FAIL")),
MessageDialog['H1'](Found solution for ODE", 'type' = 'information'));
> Maplets[Display](maplet);
Do you guys see where's the problem here?
