Question: minimization problem
UncertaityofCalibrat.mw
within the attached document, is the idea that I would like to develop with the optimization package.
I have the following set of data with their uncertainties:
Vector Measurements
<t1,t2,t3,t4,t5,R1,R2,R3,R4,R5>
<0.0000, 14.9980, 19.9990, 24.9980, 0.0000, 99.96650, 105.80750, 107.74890, 109.68870, 99.96650>
Vector of uncertainty:<0.0050, 0.0050, 0.0050, 0.0050, 0.0050, 0.0049 ,0.0049, 0.0048, 0.0050 ,0.0049>
The measured values of the temperatures t1,…, t5 are assumed to have
correlation coefficients r(ti, tj)=0.9, ij, and the measured values of the resistances R1,…, R5 are
assumed to have correlation coefficients r(Ri, Rj)=0.9, ij.
Gven the measured values z, the least squares estimates ζ and β of the quantities ζ and β are
found by minimizing the quadratic form
χ2(ζ;z) =(z−ζ)S1(z−ζ)
with respect to ζ =(t1..t5 , R1..R5 ) T under the five constraints
R0 (1 + A*ti +B*ti2)-Ri,  i=1..5
I tried to do using LSSolve from optimization package.Could give me some suggestion. I developed
through a procedure, but neither is very efficient. As I like to do with LSSolve.
