Question: differentiation results oscillations
I would like to compare different decision methods. All these methods can be described in general with the  following function:
f:= (X::Matrix,C::Vector)-> TerminalScores::Vector
In my comparison I fix C, and X to constant numeric values. The exception is  X[1,1] :=t parameter. Hence with the unapply(f(X,C),t) I can generate a single-parameter function for each method.
Fist, I would like to diffrentiate the methods (f1, f2, f3) based on t (the only variable) -> D(f1),D(f2),D(f3)
Secondly, I would like to calculate the pairwise distances defined as: distance1=abs(D(f2)-D(f1)) and distance2=abs(D(f3)-D(f1))
Thirdly, I would like to integrate these distances to get a kind of "distortion" metric compared to f1: int(distance1,t) and int(distance2,t).
After some help (from pagan, thank you again), this almost works, but I experienced the following problem:
The differentiation of the second method f2 (called dia, see termScores[2], and diffTermScore[2]) results in oscillated function, even if the plot of f2 seems to be nice . I show this in the example below on a small region, t=0.39..0.3900003
So, do you know what is the cause of this oscillation? BR, Zoltán Faigl
sumNorm:=proc(X)
local k,l,xnorm,N,M,output;
if (typematch(X,Matrix)) then
        N,M:=Dimensions(X);
        for k to M do:
                for l to N do:
                        xnorm[l,k]:=X[l,k]/add(X[i,k],i=1..N);
                od;
        od;
        output:=Matrix(N,M,xnorm)
elif (typematch(X,Vector)) then
        N:=Dimensions(X);
        for l to N do:
                xnorm[l]:=X[l]/add(X[i],i=1..N);
        od;
        output:=Vector(N,xnorm)
end if;
output;
Let's compare three score aggregation method. All are f:=(X::Matrix,C::Vector) -> TerminalScores::Vector
1st method: simple weighted sum
simpleWeightedSum:=proc(X::Matrix,C::Vector)
        local i,j,k,l,t,N,M;
        N,M:=Dimensions(X);
        # simple weighted sum
        for j from 1 to N do:
                t[j]:=add(C[i]*X[j,i],i=1..M);
        od;
        sumNorm(Vector(N,t));
2nd method: distance to ideal alternative
dia:=proc(X::Matrix,C::Vector)
        local i,j,k,l,t,v,Dpos,Dneg,Dposmin,Dnegmax,N,M;
        N,M:=Dimensions(X);
        #DiA
        for i to M do:
                for j to N do:
                        v[j,i]:=C[i]*X[j,i];
                od;
        od;
        i,j:='i','j';
        for j to N do:
                Dpos[j]:=add(  abs(v[j,i] - max(seq(v[k,i],k=1..N)) ) ,i=1..M );
                Dneg[j]:=add(  abs(v[j,i] - min(seq(v[k,i],k=1..N)) ) ,i=1..M );
        od;
        j,k:='j','k';
        Dposmin:=min(seq(Dpos[j],j=1..N));
        Dnegmax:=max(seq(Dneg[j],j=1..N));
        j:='j';
        for j to N do:
                t[j]:=sqrt((Dpos[j]-Dposmin)^2+(Dneg[j]-Dnegmax)^2);
        od;
        Vector(N,1)-sumNorm(Vector(N,t));
        #Vector(N,t);
3rd method:topsis
topsis:=proc(X::Matrix,C::Vector)
        local i,j,t,v,Dpos,Dneg,N,M;
        N,M:=Dimensions(X);
        #TOPSIS
        for i to M do:
                for j to N do:
                od;
        od;
        i,j:='i','j';
        for j to N do:
                Dpos[j]:= sqrt(add( (v[j,i] - max( seq( v[j,i],j=1..N ) ))^2, i=1..M));
                Dneg[j]:= sqrt(add( (v[j,i] - min( seq( v[j,i],j=1..N ) ))^2, i=1..M));
        od;
        j:='j';
        for j to N do:
                t[j]:= Dneg[j]/(Dneg[j]+Dpos[j]);
        od;
        #Vector(N,t);
Number of methods to compare
numOfMethods=3;
1st input parameter of methods
X:=Matrix(3,3,<<t,0.5,0.5>|<0.5,0.5,0.5>|<0.5,0.5,0.8>>);
2nd input parameter of methods
C:=Vector(3,1/3);
I want to analyze the difference between the methods, by calculating :
   distortion1:=int(abs(terminalScore[1]_dia - terminalScore[1]_simpleWeightedSum, t=0..1), and
   distortion2:=int(abs(terminalScore[1]_topsis - terminalScore[1]_simpleWeightedSum, t=0..1)
Here I create a vector of the three decision method functions
createFunctionVector:=proc(t)
        global X,C,numOfMethods;
        local f;
        f[1]:=unapply(simpleWeightedSum(X,C),t);
        f[2]:=unapply(dia(X,C),t);
        f[3]:=unapply(topsis(X,C),t);
        Vector(3,i->f[i](t)[1]);
termScores is the Vector of decision method functions
termScores:=createFunctionVector(t):
Now I create a procedure to differentiate the decision method functions
fDiffx:=proc(X,methodList)  # differentiate functions based on t
        local i,tmp;
        for i in methodList do:
                tmp[i]:=diff(simplify(convert(X[i],rational)),t) assuming t>=0, t<=1;
        od;
        Vector(3,i->tmp[i]);
call the procedure to differentiate decision method function 1 and 3, i.e., simpleWeightedSum and Topsis
diffTermScores:=fDiffx(termScores,[1,2,3]):
Now I look the "distance" of method topsis from simpleWeightedSum
distanceOfMethods:=Vector(2,<abs(diffTermScores[2]-diffTermScores[1]),abs(diffTermScores[3]-diffTermScores[1])>):
Before integration I replace undefined values to 0
tmp[1]:=unapply(subs(undefined=0,distanceOfMethods[1]),t):
tmp[2]:=unapply(subs(undefined=0,distanceOfMethods[2]),t):
I try to integrate (at least numerically) the distance of two methods to get the distortion of Topsis compared to simple weighted sum
distortion:=evalf(Int(tmp[1],0.0..1,epsilon=1e-4,digits=10)); # integration did not work for tmp[1] (DIA-WS)
distortion:=evalf(Int(tmp[2](t),t=0.0..1,epsilon=1e-4,digits=10)); # integration worked for tmp[2]
Download question_differentia.mws
