Consider you have an expression like:
f := (125*x^3+525*x^2*y+735*x*y^2+343*y^3-36*z^2)/(-216*z^3+25*x^2+70*x*y+49*y^2)
By hand and spending much time maybe we can find out so far that:
f := ((5*x+7*y)^3-(6*z)^2)/((5*x+7*y)^2-(6*z)^3)
I thought that the code `combine(f)` would give us the second one, but it didn’t. Is there anything obvious I cannot see?
Thanks for the time.
I am fairly new to Maple and cannot figure this out.
I'm having some trouble in computing formally the derivatives of
some composite functions
h:= x -> f(g(x)),
imposing conditions on the unknown functions f and g.
For example, I cannot find a way to impose g'(0)=0,
such that the computation of
h'(0)
simply gives 0.
Thank you in advance!
with(StringTools):
FormatTime("%m-%d-%Y, %H:%M")
Pile spacing of each pile from a refrence pile:
S__p := Matrix(9, 9, {(1, 1) = 0., (1, 2) = 3.30, (1, 3) = 6.60, (1, 4) = 3.30, (1, 5) = 4.67, (1, 6) = 7.38, (1, 7) = 6.60, (1, 8) = 7.38, (1, 9) = 9.33, (2, 1) = 3.30, (2, 2) = 0., (2, 3) = 3.30, (2, 4) = 4.67, (2, 5) = 3.30, (2, 6) = 4.67, (2, 7) = 7.38, (2, 8) = 6.60, (2, 9) = 7.38, (3, 1) = 6.60, (3, 2) = 3.30, (3, 3) = 0., (3, 4) = 7.38, (3, 5) = 4.67, (3, 6) = 3.30, (3, 7) = 9.33, (3, 8) = 7.38, (3, 9) = 6.60, (4, 1) = 3.30, (4, 2) = 4.67, (4, 3) = 7.38, (4, 4) = 0., (4, 5) = 3.30, (4, 6) = 6.60, (4, 7) = 3.30, (4, 8) = 4.67, (4, 9) = 7.38, (5, 1) = 4.67, (5, 2) = 3.30, (5, 3) = 4.67, (5, 4) = 3.30, (5, 5) = 0., (5, 6) = 3.30, (5, 7) = 4.67, (5, 8) = 3.30, (5, 9) = 4.67, (6, 1) = 7.38, (6, 2) = 4.67, (6, 3) = 3.30, (6, 4) = 6.60, (6, 5) = 3.30, (6, 6) = 0., (6, 7) = 7.38, (6, 8) = 4.67, (6, 9) = 3.30, (7, 1) = 6.60, (7, 2) = 7.38, (7, 3) = 9.33, (7, 4) = 3.30, (7, 5) = 4.67, (7, 6) = 7.38, (7, 7) = 0., (7, 8) = 3.30, (7, 9) = 6.60, (8, 1) = 7.38, (8, 2) = 6.60, (8, 3) = 7.38, (8, 4) = 4.67, (8, 5) = 3.30, (8, 6) = 4.67, (8, 7) = 3.30, (8, 8) = 0., (8, 9) = 3.30, (9, 1) = 9.33, (9, 2) = 7.38, (9, 3) = 6.60, (9, 4) = 7.38, (9, 5) = 4.67, (9, 6) = 3.30, (9, 7) = 6.60, (9, 8) = 3.30, (9, 9) = 0.})
Angle of each pile from a reference pile in radian:
xi := Matrix(9, 9, {(1, 1) = 0., (1, 2) = 0., (1, 3) = 0., (1, 4) = 1.57, (1, 5) = .785, (1, 6) = .464, (1, 7) = 1.57, (1, 8) = 1.11, (1, 9) = .785, (2, 1) = 3.14, (2, 2) = 0., (2, 3) = 0., (2, 4) = 2.36, (2, 5) = 1.57, (2, 6) = .785, (2, 7) = 2.03, (2, 8) = 1.57, (2, 9) = 1.11, (3, 1) = 3.14, (3, 2) = 3.14, (3, 3) = 0., (3, 4) = 2.68, (3, 5) = 2.36, (3, 6) = 1.57, (3, 7) = 2.36, (3, 8) = 2.03, (3, 9) = 1.57, (4, 1) = 1.57, (4, 2) = .785, (4, 3) = .464, (4, 4) = 0., (4, 5) = 0., (4, 6) = 0., (4, 7) = 1.57, (4, 8) = .785, (4, 9) = .464, (5, 1) = 2.36, (5, 2) = 1.57, (5, 3) = .785, (5, 4) = 3.14, (5, 5) = 0., (5, 6) = 0., (5, 7) = 2.36, (5, 8) = 1.57, (5, 9) = .785, (6, 1) = 2.68, (6, 2) = 2.36, (6, 3) = 1.57, (6, 4) = 3.14, (6, 5) = 3.14, (6, 6) = 0., (6, 7) = 2.68, (6, 8) = 2.36, (6, 9) = 1.57, (7, 1) = 1.57, (7, 2) = 1.11, (7, 3) = .785, (7, 4) = 1.57, (7, 5) = .785, (7, 6) = .464, (7, 7) = 0., (7, 8) = 0., (7, 9) = 0., (8, 1) = 2.03, (8, 2) = 1.57, (8, 3) = 1.11, (8, 4) = 2.36, (8, 5) = 1.57, (8, 6) = .785, (8, 7) = 3.14, (8, 8) = 0., (8, 9) = 0., (9, 1) = 2.36, (9, 2) = 2.03, (9, 3) = 1.57, (9, 4) = 2.68, (9, 5) = 2.36, (9, 6) = 1.57, (9, 7) = 3.14, (9, 8) = 3.14, (9, 9) = 0.})
Angle of each pile from a reference pile in degrees:
theta := Matrix(9, 9, {(1, 1) = 0., (1, 2) = 0., (1, 3) = 0., (1, 4) = 90.0, (1, 5) = 44.8, (1, 6) = 26.6, (1, 7) = 90.0, (1, 8) = 63.6, (1, 9) = 44.8, (2, 1) = 180., (2, 2) = 0., (2, 3) = 0., (2, 4) = 135., (2, 5) = 90.0, (2, 6) = 44.8, (2, 7) = 116., (2, 8) = 90.0, (2, 9) = 63.6, (3, 1) = 180., (3, 2) = 180., (3, 3) = 0., (3, 4) = 153., (3, 5) = 135., (3, 6) = 90.0, (3, 7) = 135., (3, 8) = 116., (3, 9) = 90.0, (4, 1) = 90.0, (4, 2) = 44.8, (4, 3) = 26.6, (4, 4) = 0., (4, 5) = 0., (4, 6) = 0., (4, 7) = 90.0, (4, 8) = 44.8, (4, 9) = 26.6, (5, 1) = 135., (5, 2) = 90.0, (5, 3) = 44.8, (5, 4) = 180., (5, 5) = 0., (5, 6) = 0., (5, 7) = 135., (5, 8) = 90.0, (5, 9) = 44.8, (6, 1) = 153., (6, 2) = 135., (6, 3) = 90.0, (6, 4) = 180., (6, 5) = 180., (6, 6) = 0., (6, 7) = 153., (6, 8) = 135., (6, 9) = 90.0, (7, 1) = 90.0, (7, 2) = 63.6, (7, 3) = 44.8, (7, 4) = 90.0, (7, 5) = 44.8, (7, 6) = 26.6, (7, 7) = 0., (7, 8) = 0., (7, 9) = 0., (8, 1) = 116., (8, 2) = 90.0, (8, 3) = 63.6, (8, 4) = 135., (8, 5) = 90.0, (8, 6) = 44.8, (8, 7) = 180., (8, 8) = 0., (8, 9) = 0., (9, 1) = 135., (9, 2) = 116., (9, 3) = 90.0, (9, 4) = 153., (9, 5) = 135., (9, 6) = 90.0, (9, 7) = 180., (9, 8) = 180., (9, 9) = 0.})
The total number of piles in a pile group:
n__pile := 9
The length of each pile in the pile group in (meters):
L__p := 12.182
Diameter of pile (meter):
`φ__pile` := .457
The radius of each pile (meter):
r__0 := evalf((1/2)*`φ__pile`, 2)
`ρ__A` := 1.0
D__s := 0.5e-1
Omega := 46``
`ν__soil` := .5
E__p := 3.2*10^10``
G__s := 5.7*10^7``
V__s := 182.88
V__La := 395.845``
`&alpha;__&nu;` := proc (S__p, xi, n__pile) local `&alpha;__tmp`, flist, i, j, `&alpha;__1`, `&alpha;__2`, `&alpha;__3`; global D__s, V__La, V__s, Omega; description "Calculate the horizontal interaction factor from a refernce pile in a pile group"; flist := []; for i to `n__pile ` do for j to n__pile do `&alpha;__1`[i, j] := evalf[4](.5*(S__p[i, j]/`&phi;__pile`)^.5*exp(-D__s*Omega*S__p[i, j]/V__La)*exp(-I*Omega*S__p[i, j]/V__La)); `&alpha;__2`[i, j] := evalf[4]((3/4)*(S__p[i, j]/`&phi;__pile`)^.5*exp(-D__s*Omega*S__p[i, j]/V__s)*exp(-I*Omega*S__p[i, j]/V__s)/sqrt(2)); `&alpha;__3`[i, j] := evalf[4](`&alpha;__1`[i, j]*cos(xi[i, j])^2+`&alpha;__2`[i, j]*sin(xi[i, j])^2); if i = j then `&alpha;__tmp`[i, i] := 1.0 elif xi[i, j] = 0. then `&alpha;__tmp`[i, j] := `&alpha;__1`[i, j] elif xi[i, j] = 1.57 then `&alpha;__tmp`[i, j] := `&alpha;__2`[i, j] elif xi[i, j] <> 1.57 and xi[i, j] <> 0. then `&alpha;__tmp`[i, j] := `&alpha;__3`[i, j] end if; flist := [op(flist), `&alpha;__tmp`[i, j]] end do end do end proc:
NULLNULL
NULLNULLNULL
`&alpha;__v` := eval(Matrix(n__pile, n__pile, `&alpha;__&nu;`(S__p, xi, n__pile)))``
Download Test_pile.mw
Good Evening Maple Community,
Can anybody please help in the attached file. Highlighted in yellow are the three equations I'm trying to program in Maple procedure, but could not get any output due to an error message. Please Help.
Boyer
Is this what is supposed to happen when linking Maple to Matlab?  I was hoping it would open the actual Matlab program and write variables to the current worksheet.  I'm I missing something?
Nothing even pops up on the Matlab Command window. What good is this?
I want to define a proc in Maple which gets an integer n and gives a set of arrays like {1,2,3}^n, meaning {[a[1],...,a[n]]|for all 1<=i<=n a[i] in {1,2,3}}. For a fix n, obviously one can use n-for, for example when n is 2
A:=Array(1..3,1..3):
for a[1] from 1 by 1 to 3 do
 for a[2] from 1 by 1 to 3 do
  A(a[1],a[2]):=[a[1],a[2]];
 end for:
end for:
But when n is not fixed, how can I tell Maple to consider n for?! Also how can ask him to make a n-dimensional array?
I have 3 equations
eq1 := vs = (Rs+Z)*i1+Z*i3
eq2 := A*vi = Z*i1+(Z+Rf+ro)*i3
eq3:= vo = (Rf+Z)*i3+Z*i1
and I want to solve for vo/vs . How to do that ?
the expected solution is
Hi;
Could anyone help me to compute the lie derivative of the function h:R^3-->R with respect to the vector-valued function f:R^5-->R^3 below?
f(x,y,L,u,v) = [x + u;
y + v;
L]
h(x,y,L) = sqrt((y-x)^2 + (L)^2)
Thank you in advance.
I have have s simple graph, see figure below. I want to export it to e.g. PDF-format.
But I want landscape, not portrait. How can I export PDF to landscape?
I tried a workaround: Export it as to JPG gives very bad quality.
I simply want to export my figures to landscape with good quality.
How can I solve this?
Here is my command
> teksbiasa:=`Kriptografi`;
teksbiasa:=Kriptografi
>len:=length(teksbiasa);
len:=11
>nilaiASCII:=convert(teksbiasa, bytes);
nilaiASCII:=[75,114,105,112,116,111,103,114,97,102,105]
>L:=[seq(i,i=nilaiASCII)]
L:=[75,114,105,112,116,111,103,114,97,102,105]
Anyone know how i need to write the command to add the lenght of the text (len) into each of the number in nilaiASCII?
What is want to get is:
[86,125,116,123,127,122,114,125,108,113,116]
Thank you~=]]
For bonus in my one class, we are required to change the code in a program to have it produce another row when running Neville's Method. We need to, after it runs initially, have it ask "Run another time? Y/N" and type 'Y' or 'N' for Yes or No. If No, it ends the program. If yes, we need to have it input another x(i) and f(x(i)) without having to input all the other data points again. Here is what I have so far (this is just the additional part we have to add, not the whole code):
 print(`Do you want another point? Type Y or N.`):
  J := scanf(` %c`)[1]:print(`Entry = `):print(J):
  if J = "Y" or J="y" then
  AGAIN := "Y":
  AGAIN = "Y" or AGAIN = "y":
        OUP := default:
      fprintf(OUP, `NEVILLE'S METHOD\n `):
       fprintf(OUP, `Table for P evaluated at X = %12.8f , follows: \n`, X):
       fprintf(OUP, `Entries are XX(I), Q(I,0), ..., Q(I,I) `):
       fprintf(OUP, `for each I = 0, ..., N where N = %3d\n\n`, N):
       for I1 from 0 to N+1 do
         fprintf(OUP, `%11.8f `, XX[I1]):
         for J from 0 to I1 do
           fprintf(OUP, `%11.8f `, Q[I1,J]):
         fprintf(OUP, `\n`):
    if J="Y" or J="y" then
         AGAIN := Y:
             if AGAIN = Y or AGAIN = y then
                 #N=N+1:
                  if N > 0 then
                  OK := TRUE:
                 for I1 from N to N+1 do
                        print(`Input X(i) and F(X(i)) for i = `):print(I1):
                        print(`separated by a space `):
                       XX[I1] := scanf(`%f`)[1]:
                       Q[I1,0] := scanf(`%f`)[1]:print(`Entries are`):print(XX[I1],Q[I1,0]):
                  print(`Number must be a positive integer `):
               fi:
                AGAIN := No:
         fi:
         fi:
        print(`Ok thanks`):
 fi:
Not sure what I am doing wrong and any help is appreciated. Thanks.
One new feature of Maple 2016 is claimed to be
          FunctionAdvisor(plot, .......)
but when I try HeunD or HeunG there is no output -- no error message, nothing.  Is this behaviour what a user should expect of this command?
I would like to scale the last KernelDensityPlot in the attached worksheet to overlay with the Histogram above it.  The result would look like the 3rd plot in the worksheet, except the y-axis ranges would match.
MonteCarloHistogram.mw
montecarloHistogramExample.txt
Georgios
I'm trying to solve a recurrence relation by generating terms and looking for a pattern.  I've learned that i can't stop
Maple's autosimplification process and the best I can do is use Parse from the InertForm package.  The hand drawn picture below is what I'm trying to replicate.  I know I can use rsolve but I'm trying to do the steps I would with pencil and paper.
I want to set the determinant of the coefficient matrix equal to zero and then solving for the roots. But I could not achieve it via Maple. Can you help me please?
You can reach two examples in the following file.  Yeni_Microsoft_Word_Belgesi_(2).docx
Besides. how can i compute the following transcental equations via maple
sinh(beta*L)*sin(beta*L)=0
cosh(beta*L)*cos(beta*L)-1=0
cosh(beta*L)*cos(beta*L)+1=0
regards
mehmet
Here is my command..
> mylist:=[4,6,2]: for x from 1 to nops (mylist) do convert (mylist[x], binary) end do;
> z:=map(convert, mylist, binary);
[100, 110, 10]
> map2(nprintf,"%08d",z);
[00000100, 00000110, 00000010]
how I need to continue the command to get the number of 1s in each of the binary number?
Thank you~=]]
`00000100`, `00000110`, `00000010`
First 1187 1188 1189 1190 1191 1192 1193 Last Page 1189 of 2470
