• Is there a simple way to find the domain for the real solutions of f(x)?
• And is there a way to let maple get the part of f(x) with the sqrt?
   (not by typing it by hand as I dit below)
• Is there a way to write the summary of the found domains in one line?
Thanks for your help.
# How to find the Domain for real solutions for x?
f(x):=(x-1+sqrt(x^2-3*x+2))/(x-1);
discont_for_x=discont(f(x),x);
# x<>+1 (because the de denom=0 is not allowed)
denom(f(x))=0;
x={solve(denom(f(x))=0,x)};
# x<=1 union  2<=x (because the part under the sqrt must be >=0 to give Real solutions)
sqrt(x^2-3*x+2);
0<=x^2-3*x+2;
x=solve(0<=x^2-3*x+2,x);
Hi all
Please, I'd like to clarify some basic points about performing computations in Maple 18. Up to now I have been doing some numeric calcs using matrices normally composed of 10 to 15 columns and 200 to 600 rows.
When doing the calcs with a matrix of ~200 rows, it is just ok but as the number of rows increase the calculation speed reduces significantly.
The data contained in each row is calculated within a loop cycle (i.e.: for i from 1 to 200 do ......).
The number of rows is controlled by a slider so when I drag the slider the calcs are automatically updated and the results shown graphically.
As I said it is too slow so I don't know if I should be looking into the option of doing calcs symbolically first? However you can't use symbolic notation when working with matrices. I still got a lot of calcs to do but prefer not to continue as it will only get slower so better to see if I can optimise speed.
Any comment is trully appreciated.
Cesar
m 18 cubacuhre integration fail, intergrand unknown
restartprintlevel = 3binomial(7, 2); with(StringTools); FormatTime(%c)with(LinearAlgebra); with(IntegrationTools)with(numapprox); with(OrthogonalSeries); LinearAlgebra:-HermitianTranspose(3-I*7)infolevel[`evalf/int`] := 4; pie = evalf(Pi)n = 1l = 0m = 0n1 = 1l1 = 0m1 = 0alpha = 5.8alpha1 = 4.2R = .5Theta = (1/6)*PiPhi = 3*Pi*(1/4)region := [r = 0 .. infinity, theta = 0 .. Pi, phi = 0 .. 2*Pi]r1 := proc (r, theta, phi, R, Theta, Phi) options operator, arrow; (r^2+R^2-2*r*R*(sin(theta)*sin(Theta)*cos(phi-Phi)+cos(theta)*cos(Theta)))^(1/2) end proc"coef:=(l1,l2,m1,m2)->(-1)^(l1-l2) (((4 *pie *(2 l1+1)!)/((2 l1-2 l2+1)!*(2 l2+1)!))*("
"(binomial(l1+m1,l2+m2)*binomial(l1-m1,l2m2))/(binomial(2* l1,2* l2)))())^(1/(2));NN:=(n,alpha)->((2 alpha)^(n+(1)/(2)))/(((2 n)!)^((1)/(2)));  "
integrand := sum(sum(R^(l1-l2)*SphericalY(l1-l2, m1-m2, Theta, Phi)*coef(l1, l2, m1, m2)*r^(2+l+l2)*SphericalY(l2, m2, theta, phi)*LinearAlgebra:-HermitianTranspose(SphericalY(l, m, theta, phi))*NN(n, alpha)*r^(n-l-1)*exp(-alpha.r)*NN(n1, alpha1)*r1(r, theta, phi, R, Theta, Phi)^(n1-l1-1)*exp(-alpha1*r1(r, theta, phi, R, Theta, Phi))*sin(theta), m2 = -l2 .. l2), l2 = 0 .. l1)
evalf(Int(integrand, region, 'epsilon' = 0.1e-3, 'method = _CubaCuhre'));
``NULL
binomial(7, 3)region4 := [x = 0 .. 10*Pi, y = 0 .. 10*Pi]
integrand4 := (cos(x)+(1/3)*sin(y))^6*(sin(y)-(1/3)*cos(x))^2
evalf(Int(integrand4, region4, 'epsilon' = 0.1e-3, 'method = _CubaCuhre'))
Download stovrlp2.mw
Hi, as the title says I am animating an implicitplot and want a different color for each curve left by the trace. I realize it may be easier to build plot structures using seq and display(..,insequence=false) but I thought I should learn more Maple ha ha. Plus  it seems easier to implement.
 Forgot to say I use Maple 15
For equation sol[2][1]=constant A,
> animate(implicitplot, [sol[2][1] = A, x = -6 .. 15, y = -15 .. 15, numpoints = 10^5], A = -10 .. 10, trace = 2, frames = 20);
Hi all
In matlab software we have a command namely fmincon which minimizes any linear/nonlinear algebric equations subject to linear/nonlinear constraints.
Now my question is that: what is the same command in maple?or how can we minimize linear/nonlinear function subject to linear/nonlinear constraints in maple?
thanks a lot
Mahmood   Dadkhah
Ph.D Candidate
I need to find mina(w) then a=-1,0,1 and
w := piecewise((x-a)/t <= -10, 202*a-200*x-(202001/101)*t, (x-a)/t <= -910/101, 3*a-x-(1011/101)*t, (x-a)/t <= 910/101, 2*a-t, (x-a)/t <= 10, a+x-(1011/101)*t, 10 < (x-a)/t, -198*a+200*x-(202001/101)*t)
Also need to plot it, i think it should look like this
I am getting a complex solution for a physical quantity, how can I plot it. Should I plot the real part or modulus?
solution is,
C1*sqrt(4*tau^2*M^2*lambda^2+Q^2)*LegendreP((1/2*I)*sqrt(7)-1/2, I*sqrt(7), (2*I)*lambda*M*tau/Q)+C2*sqrt(4*tau^2*M^2*lambda^2+Q^2)*LegendreQ((1/2*I)*sqrt(7)-1/2, I*sqrt(7), (2*I)*lambda*M*tau/Q)
where C1 and C2 are integration constants.
Perhaps I am being daft, but to me the Physics package seems, quite surprisingly, to have trouble multiplying by a nonzero, non-square matrix. The test code
with(Physics):
Matrix(2,2,fill = 0) . Vector(2),
Matrix(2,2,fill = 1) . Vector(2),
Matrix(2,3,fill = 0) . Vector(3);
Matrix(2,3,fill = 1) . Vector(3);
produces the following output:
Error, (in Vector[column]) Matrix index out of range
i.e., the last expression cannot be evaluated; while the test code (where no loading of the Physics package is performed)
#with(Physics):
Matrix(2,3,fill = 0) . Vector(3),
produces the following expected output:
PS: To be sure, I have from http://www.maplesoft.com/products/maple/features/physicsresearch.aspx downloaded the latest version (2014, March 19, 4:0 hours) of the Physics package for Maple 17 (the version I am running).
Please i don't want to convert from list to set then apply set minus and convert back because it loses its order and repititions.
so i want something that can for example do the following:
list_minus([1,2,4,6,2,1,3,6,2],[7,4,2,5,2]) = [1,6,1,3,6,2]
so it removes repititions from left and order is retained.
Hi all
I dont know why some Z1 appears on the screen and the code does not converge.
please help me
thanks alooooot
n:=3;
nn:=3;
m:=1;
BB:=1;
BINF:=5:
pr:=7;
digits:=10;
eq1:=diff(f(tau),tau$3)+((3/5)*f(tau)*diff(f(tau),tau$2))-(1/5)*(diff(f(tau),tau$1))^2+((2/5)*tau*diff(h(tau),tau$1))-((2/5)*h(tau))-BB*diff(f(tau),tau$1)=0;
eq11:=(1/pr)*diff(h(tau),tau$3)+(3/5)*f(tau)*diff(h(tau),tau$2)=0;
h(tau):=sum(p^i*h[i](tau),i=0..nn);
f(tau):=sum(p^i*f[i](tau),i=0..n);
H1:= p*(diff(f(tau),tau$3)+((3/5)*f(tau)*diff(f(tau),tau$2))-(1/5)*(diff(f(tau),tau$1))^2+((2/5)*tau*diff(h(tau),tau$1))-((2/5)*h(tau))-BB*diff(f(tau),tau$1))+(1-p)*(diff(f(tau),tau$3)):
H11:= p*((1/pr)*diff(h(tau),tau$3)+(3/5)*f(tau)*diff(h(tau),tau$2))+(1-p)*(diff(h(tau),tau$3)):
eq2:=simplify(H1):
eq22:=simplify(H11):
eq3:=collect(expand(eq2),p):
eq33:=collect(expand(eq22),p):
eq4:=
convert(series(collect(expand(eq2), p), p, n+1), 'polynom');
eq44:=
convert(series(collect(expand(eq22), p), p, n+1), 'polynom');
for i to n do
s[i] := coeff(eq4, p^i) ;
print (i);
for i to nn do
ss[i] := coeff(eq44, p^i) ;
print (i);
s[0]:=diff(f[0](tau), tau$3);
ss[0]:=diff(h[0](tau), tau$3);
ics[0]:=f[0](0)=0, D(f[0])(0)=0, D(f[0])(BINF)=0;
icss[0]:=h[0](BINF)=0, D(h[0])(0)=1, D(h[0])(BINF)=0;
dsolve({s[0], ics[0]});
f[0](tau):= rhs(%);
#dsolve({ss[0], icss[0]});
h[0](tau):= -exp(-tau); #;rhs(%);
for i to n do
f[ii-1](tau):=convert(series(f[ii-1](tau), tau, nn+1), 'polynom');
h[ii-1](tau):=convert(series(h[ii-1](tau), tau, nn+1), 'polynom');
s[i]:=simplify((s[i]));
ics[i]:=f[i](0)=0, D(f[i])(0)=0, D(f[i])(BINF)=0;
dsolve({s[i], ics[i]});
f[i](tau):=rhs(%);
ss[i]:=(ss[i]);
icss[i]:=h[i](BINF)=0, D(h[i])(0)=0, D(h[i])(BINF)=0;
dsolve({ss[i], icss[i]});
h[i](tau):=rhs(%);
f(tau):=sum((f[j])(tau),j=0..n);
with(numapprox):
plot(diff(f(tau),tau),tau=0..5,color=blue,style=point,symbol=circle,symbolsize=7,labels=["tau","velocity"]);
plot(pade(diff(f(tau),tau), tau, [7, 7]),tau=0..5,color=blue,style=point,symbol=circle,symbolsize=7,labels=["tau","velocity"]);
x*(y+z)/x
convert any polynomial to Divide(Mult(x, Plus(y+z)), x)
Hi can you please help me? I want to write a program in Maple code, using the Newton-Raphson method, to solve the equation tan(x) −x-1=0 .  the approximate root is 1.5.
I tried doing this using a while loop to compare the last and current iterates, but something is not working.
so can you please help me do that?
y = -x+sqrt(-5*x)
how to plot this in 2d or 3d graph
What is the reason/Why:
Error, (in dsolve/numeric/bvp) unable to achieve requested accuracy of 0.1e-5 with maximum 128 point mesh (was able to get 0.66e-1), consider increasing `maxmesh` or using larger `abserr`
Thanks for the help :)
I'm trying to plot the direction field of the second order differential equation x''=x'-cos(x) using dfieldplot:
> with(DEtools); with(plots);
> f1 := (x, y) options operator, arrow; diff(x(t), t)-cos(x(t)) end proc;
/ d \
(x, y) -> |--- x(t)| - cos(x(t))
\ dt /
> dfieldplot([diff(x(t), t) = y(t), diff(y(t), t) = f1(x(t), y(t))], [x(t), y(t)], t = -2 .. 2, x = -2 .. 2, y = -2 .. 2);
Error, (in DEtools/dfieldplot) cannot produce plot, non-autonomous DE(s) require initial conditions.
The error I'm getting says I need initial conditions, but I wasn't provided with any. Is there another way to plot this? Sorry if this is dumb question, but I've only ever plotted first order equations.
First 1486 1487 1488 1489 1490 1491 1492 Last Page 1488 of 2471
