Given the following information: f:=sin(3*(t)) (0 <><><>
I am currently working on a project with Maple, and I am stumped beyond belief. The first I have been working on for something like two weeks now. I have worked on it with the university computers, and my own computer and recieved the exact same error. I don't see any syntax errors, and apparently the TA has been able to get his to work. So could someone possibly point out my stupid mistake? f1:= (2*x(c-Pi/2))/sqrt(1-sin(c)); fint:= int(f1, x=0..1); limit(fint,c=(Pi/2), right); And it outputs the following: signum(int(2*x(0)*sqrt(2), x = 0 .. 1))*infinity
Hi, Does the 'restart' command clear all the packages that have previously been loaded? example: with(package1): with(package2): " " " Maple commands and general problem solutions Then in the same worksheet following the previous work restart Do I have to reload the packages or does Maple just reset the variables used to null? tia Larry Ciak
If the finite field is Zp (p a prime) then it's easy. But what if the field is say, GF(2,3,x^3+x+1)? Suppose, for example, I entered: r:=rand(8): G:=GF(2,3,x^3+x+1): M:=Matrix(3,3,(i,j)->G[ConvertIn](x^r())); How would I invert M (over the field G); multiply M by another matrix, and so on? Can I do this with the Domains package? Thanks, Alasdair
I want to use command line maple to plot a function and capture its graph directly to a *.gif file without displaying it. How do I do it? I've gotten Matlab to do it, but can't seem to find the necessary syntax in Maple. Thanks, Eddie
I'm having trouble plotting Planck's Radiation Formula in terms of wavelength, assuming a perfect black body radiator temperature of 5800K. Here are some of my efforts. Can anyone help ? thanks, View 285_EENG501Homework2.mw on MapleNet or Download 285_EENG501Homework2.mw
View file details
I have been tasked with the following job by my former advisor, and I have not be able to find an answer as of yet: can Maple make a 3-D plot of a cube with a moving sphere or ball inside of it. The animation of the sphere would be as follow: moving along each of the three major axis of the graph to highlight them. The animated sphere would also have to move continuously through the axis (or discretely over such small increments as to appear to be moving continuously.) Can anyone help me with this? Thanks in advance. Chris W.
I installed Maple T.A. 2.5 on Fecora Core 4, and it can be started on the XWindow. I added the command "MapleTA_installed_dir/bin/mapleta.sh start" at the buttom of the script /etc/rc.d/rc.local, and I hopeed Maple T.A. service can be started when I reboot the system. But It doesn't work !! That means I have to go to the front of the machine, then I can start Maple T.A. service. It's very inconvenient for me. The following message is came from logs/mapleta.out loading... Root Empty Class loading... Maple T.A. Demonstration Class Exception in thread "main" java.lang.InternalError: Can't connect to X11 window server using ':0.0' as the value of the DISPLAY variable.
other post I am trying to solve the following problem and many others like it but showing how to do it step by step. f := [z = (1+y+y^2-y^3)/(1-y)^3] I am to pick a value for z between 0.601 and 0.899, I chose 0.8 since its as close to a solid number as I could get. z := `0.8` eval(f) z := 0.8 eval(f) hmmm still not solving or breaking down the problem, just showing my the problem with 0.8 in place of z solve(f)
Has anyone written a MAPLE program to solve sudoku puzzles?
Hi, as I did not receive a response to my first post I renew it with more details. I use Maple10 for Prof. under the operating system XP pro. My Maple is out of order because my "kernel connection is not available" and Maple is closed by "mserver.exe"; yet my firewalls are stopped when I open Maple. Before this problem Maple did'nt find the dll:"libgmp-3.dll". I reinstalled Maple but the problem is the same. What can I do? Thanks
Hi there, I am trying to show/color the region which satisfies some inequality, say x^2+y^2
I am a new-to-ubuntu (edubuntu) user, wondering, which version of maple should I purchase to install? SuSE? Mandrake? Hmm, I'm going to qualify my inability to find the answer own my own with, "i tried really hard to do it on my own teach." Thanks in advance.
This may be a very easy question to answer. But I can't get maple to plot a function. What I need is a 3D plot of: v2 vs epsilon vs r With the variable k varying between 1 and 2, and r varying between 1 and 250. but every time I try to plot, the program gives an error "Warning, unable to evaluate the function to numeric values in the region; see the plotting command's help page to ensure the calling sequence is correct". But if you manually calculate v2 and epsilon using the values given, they wrk out fine. I'm sure I'm just not doing something right but I can't seem to figure out what.
What if, for display purposes, you wish the output of an execution group to look exactly a certain way. For example, I am trying to get the output to look exactly like Maple Equation
The use of single quotes doesn't seem to do the trick.
> Maple Equation
First 2415 2416 2417 2418 2419 2420 2421 Last Page 2417 of 2469
