HI all,
Let all variables be integers here.
I am trying to search 3 variables , "A","B",and "C" so that f(A*x2+B*x+C) factors into two binomials.
Here, f(y) = y2+y+19.
Choose a search space of 0<A<10 and 0<B<30 and 0<C<100.
I am having some trouble with my Maple code.
Here is how far I got -
Maple_coefficient_search_broken.mw
Maple_coefficient_search_broken.pdf
Matt
I want to visualize data provided by the Maximize command. The output I get is of the following form (example):
 [.358700275060090779, [p[0] = .192413186080606, p[1] = 0.906594292940704e-1, p[2] = 0.677108912885780e-1, p[3] = 0.609551830556988e-1, p[4] = 0.589744573790909e-1, p[5] = 0.585737058072817e-1, p[6] = 0.589744573787748e-1, p[7] = 0.609551830550955e-1, p[8] = 0.677108912877626e-1, p[9] = 0.906594292931833e-1, p[10] = .192413186079858]]
I want to plot the sequence p[0], ..., p[10] with the command LineChart (for example).
My question is: How to automatically "clean up" output as above so I can feed it to LineChart?
with(DifferentialGeometry): with(Tensor):
DGsetup([x1, x2, x3, x4], M)
g1 := evalDG(dx1dx3+dx2dx4-u22(dx3)^2-u11(dx4)^2+2*u12*dx3dx4)
C1 := Christoffel(g1)
^^^ This is my code, I know theres something wrong with the metric but I'm not sure what, any help would be appreciated thanks! (This code gives me no answer).
u11*u22-u12^2+u13+u24 = 0   - This is the original eq I was working off.
I need code for finding the order of convergence of helleys method its really urgent please help
Dear members,
Having learnt the use of parse, I tried making a document with module. The document works fine. But I could not not take the codes inside the ComboBoxes inside module UpdateExpr().
Also initialisation does not work since parse command is not allowed by maple here as can be seen by the output in MathContainer_fplusx below.
The document works fine after executing !!!.
Can any one help me avoid all the codes inside combobox except the UpdateExpr() code, please? Thanks.
Ramki.
Composition of Functions
Select f(x) and g(x)
 f(x)*is
  g(x)*is
(f+g)(x)
Download Composition_of_Functions_Doubt.mw
Does maple has an in-built command for levy distribution? Thank you.
Is there any packages / function I can use to ...? I've checked the Physic [Diff] about diff on function with anticommutative variables.
As i know i can introduce a proc like: theta*diff(f,x)+diff(f,theta)  where f is a super-function to represent superderivation.
Question is I want treat super-derivative as one operator not a combination, because i wanna compare the order like comparing order of diff(f,x).
Any advice on dealing super function by maple is needed. My first time dealing with super function i havent got any clues..
Dear members,
I have made a simple document with 3 components ComboBox, TextArea and MathContainer.
A selection from ComboBox gets entered into TextArea, but not in MathContainer. I tried all codes with and without quotes, expression, value, "value" etc.
Any simple code I missed, please let me know.
Ramki
``This is a comboBox to select an expression for entry into TextArea0 and MathContainer0
TextArea0            This is MathContainer0
Codes in ComboBox EditSelectCode
use DocumentTools in
s:=GetProperty("ComboBox0","value");
SetProperty("TextArea0","value",s);
SetProperty("MathContainer0","expression",GetProperty("TextArea0","value"));
end use;
Download MathContainerEntry_Doubt.mw
Hi, I want to study the Maths in a online university, And I will use Maple for my study. Can I purchase the maple student version?
Which version can maple use GPU with SageMaker in amazon P3?
i want to increase the speed of maple
do I need to upload a maple setup file or maple has this?
A=(1  1)
     (1  0)
Determine the smallest natural number n such that the matrix A^n contains
an entry greater than 2019.
(I know the answer is A^17, but I don't know how to use maple in order to determine when an entry becomes greater than 2019.)
Suppose that (x1, x2, . . . , xn) is a sequence of real numbers. The mean μ and the standard deviation σ are defined as
μ= n(x1 +x2 +...+xn);
σ=√[(1/2)n[(x1 −μ) +(x2 −μ) +...+(xn −μ) ]]
1. Suppose that n = 20 and xk = k for all k. Write for loops to determine the mean and the standard deviation of the sequence.
2. Suppose that n = 30 and xk = k3 for all k. Write for loops to determine the mean and the standard deviation of the sequence.
I use the following plot in Maple 13. I would like to have the colorbar also along with the plots. Help me to write the commands to get the colorbar.
I have made a document with mathContainer, plot component and sliders, which works fine, but needs the startup code to be run manually, everytime to remove the plot error message, popping out in the first instance.
              unrecognized function "inequal" where PLOT DAG expected
I donot know the mistake I have made.
Thanks for any suggestion.
Ramki.
a:
b:
Download Doubt_on_inequalCommand.mw
I have an array which coloumns represents coordinates of the different points. Points connected should display some kind of a line. Every row represents coordinates for different time step.
I am trying to plot the animation od that line movement during the time. Any suggestions on this animation? It is easy to plot points and lines for one of the rows in the array, but I cannot make it to automaticly animate it through time steps.
First 756 757 758 759 760 761 762 Last Page 758 of 2469
