Calculate the values of the following determinants
I have sets of names with numeric parts like X:={x12, x1, x3, x15, x2, x9}.
How can I sort X based on the numeric part so Xsort:={x1, x2, x3, x9, x12, x15}.
Hi.
Why maple can not compute integral?
int.mw
Is this internal error expected? Why does it happen? Reported to Maplesoft just in case.
e:= RootOf(csc(_Z));
simplify(e);
RootOf(csc(_Z))
Error, (in simplify/trig/do/1) expression independent of, _Z
e:= RootOf(csc(x));
simplify(e);
RootOf(csc(_Z))
Download simplify_Z_error_maple_2024_march_22_2024.mw
ps. Reported to Maplesoft just in case.
Only for my understanding. In the following I need to use expand to apply division to list elements when the divisor is a name:
[a, b]*(1/2)
[(1/2)*a, (1/2)*b]
[a, b]/c
[a, b]/c
expand([a, b]/c)
[a/c, b/c]
Does in this case automatic simplification make a difference between numbers and names? (Probably this is explained somewhere.)
Download div_of_list.mw
Why does the Heaviside function work this way? Is this some kind of bug? The integral of this graph over the interval -1..1 cannot be equal to zero.
int_of_V-func.mw
I do not like this feature at all. called Scrollable Matrices:
https://mapleprimes.com/maplesoftblog/224789-Discover-Whats-New-In-Maple-2024
Is there a way to turn it off?
In Maple 2024 when I display a wide matrix, it no longer wraps around if the worksheet window width was smaller as it did in Maple 2023. I prefer the 2023 behavior.
A:=Matrix(3,4,{(1, 1) = (y(x) = RootOf(-Intat(1/(_a^(3/2)+1),_a = _Z+x)+x+Intat(1/
(_a^(3/2)+1),_a = 0))), (1, 2) = "explicit", (1, 3) = "", (1, 4) = false, (2, 1
) = (y(x) = -1/2+1/2*I*3^(1/2)-x), (2, 2) = "explicit", (2, 3) = "", (2, 4) =
false, (3, 1) = (x = -2/3*ln(((y(x)+x)^(3/2))^(1/3)+1)+1/3*ln(((y(x)+x)^(3/2))^
(2/3)-((y(x)+x)^(3/2))^(1/3)+1)+2/3*3^(1/2)*arctan(1/3*(2*((y(x)+x)^(3/2))^(1/3
)-1)*3^(1/2))+1/9*3^(1/2)*Pi), (3, 2) = "implicit", (3, 3) = "", (3, 4) = true}
,datatype = anything,storage = rectangular,order = Fortran_order,shape = []);
Screen shot on Maple 2023
Screen shot on Maple 2024
I looked at Tools->options->Display and Interface but see nothing there to turn it off.
Maple 2024 on windows 10.
Windows 10 64bit
If I double click on a  file to open it from explorer  i.e. launch Maple, it is 50/50 whether Maple hangs on opening the file and I have to kill it in the Task Manager. This only happens the 1st time I try to open the file. Subsequent clicks on it will open it. If Maple is already open the problem does not happen.  The problem willl also be there after the PC is restarted. Has anyone else noticed this?
Dear Users!
I hope everyone here is fine. In the attached file I have a list of points in three dimensions. I want to plot surfaceplot (also in Dimension=2) of only those points which are less than 1.
But I want to plot the density plot for all points with the range on x-axes 5 to 15 and the range on y-axes 50-1000
Help.mw
I got a plot by following the code in Mpale 2022.
P2 := plot3d(-t^2 + x, t = 0 .. 20, x = 0 .. 400, labels = ['t', 'x', 'rho'], labelfont = [Times, 15], viewpoint = "circleleft", colorscheme = ["ygradient", ["Green", "Purple", "Blue", "Red", "BlueViolet"]]);
plotsetup(ps, plotoutput = "P2");
print(P2);
Then I tried the following code for the overleaf. However, I did not get the desired result.
\documentclass[11pt]{article}
\usepackage{graphicx}
\usepackage{epsfig}
\begin{document}
Plot obtained from Maple 2022. \\
\includegraphics[width=0.9\textwidth]{P2.eps}
\end{document}
plotting_file.pdf
Any help is highly appreciated.
Deb
So linalg had iszero function, but the newer LinearAlgebra does not? I find it in ArrayTools. Have they split the old linear algebra package into two?
Let SABCD be a pyramid, with the line SA perpendicular to the plane ABCABCD is a rectangle, AB = aAB = bSA = hH is projection point of A on the line SC and K is projection point of A on the line SD. How can I find radius of the circumcircle of triangle CHK?
A := [0, 0, 0];
B := [a, 0, 0];
C := [a, b, 0];
DD := [0, b, 0];
S := [0, 0, h];
lineSC := Line(S, C);
lineSD := Line(S, DD);
H := Projection(A, lineSC);
K := Projection(A, lineSD);
I'm seeking an efficient solution to a particular problem. To illustrate, I'll provide a simplified example, though in practice, I'm handling lists with millions of elements.
Let's take the list, l: [1, 2, 3, 4, 5, 6, 7, 8]. Each element in this list has a corresponding twin. For instance, 1 has twins [4, 5], and 2 has twins [9, 12] (note that 12 is not in the original list, but that's not problematic). The complete list of twins is represented as t: [[4, 5], [9, 12], [6, 8], [1, 5], [1, 4], [3, 8], [13, 14, 17], [3, 6], [2, 12], [11, 12, 15]], and the twins are made available as they are needed.
The objective is to remove all twins starting from the first element of the list. Once a twin is removed, there's no need to check for twins for that particular element. For example, consider the first element, 1; the twins [4, 5] are removed, and there's no need to find the twins for those elements. The desired outcome would be the list [1, 2, 3, 7,10].
My solution utilizes a combination of a while loop and sets. However, it's painfully slow when dealing with lists larger than a few hundred thousand elements.
Many thanks.
Dear Power Users, I am trying to master Maple coming from another software. I encounter a problem in finding a simple way to find the best parameters for a fitting function. Would someone be so kind to help me out? Thank you in advance for your willingness to help.
FindOptimizedParametersFit.mw
I am looking to refine my animation. I would like to add a condition on the colors to illustrate the periodicity of the sine function: the first circle in red, and the curve in red from 0 to 2π, then the second circle in blue and the curve in blue from 2π to 4π, etc. Any ideas? Thank you very much in advance.
AnimSinusCouleurs.mw
First 123 124 125 126 127 128 129 Last Page 125 of 2430
