I want to illustrate the intersection between The ellipsoid   "x^2/4 + y^2/9 + z^2/16 = 1"and the plane  "z = 3"
Normally, I should obtain an ellipse G1, but its graph does not match the graph obtained ? Thanks for your ideas
G2Exercice1.mw
How to solve this RLC Electric Circuit  with this initial conditions,I couldn't plot this equation.Help me to do this problem.
EC-2.mw
Let y>1. It can be proved (maybe by hand) that the following four expressions are mathematically equivalent:
assume(y > 1); # Assumption!
expr := [0, 0, 0, 0]: # Preallocation.
expr[1] := exp(y*LambertW(ln(y))):
expr[2] := (ln(y)/LambertW(ln(y)))^y:
expr[3] := eval(x^(x^x), x = exp(LambertW(ln(y)))):
expr[4] := eval(x^(x^x), x = ln(y)/LambertW(ln(y))):
But unfortunately, when I tried to simplify expri - exprj (symbolically), I just got:
seq(seq(ifelse(j <> i, [i, j, verify(expr[j], expr[i], equal)], NULL), j = 1 .. numelems(expr)), i = 1 .. numelems(expr)); # is(expr[j] = expr[i]) does not work as well.
   [1, 2, FAIL], [1, 3, FAIL], [1, 4, FAIL], [2, 1, FAIL],
     [2, 3, FAIL], [2, 4, FAIL], [3, 1, FAIL], [3, 2, FAIL],
     [3, 4, true], [4, 1, FAIL], [4, 2, FAIL], [4, 3, true]
In other words, Maple can only determine that expr[3] = expr[4].
One may check that, for example,
MmaTranslator:-Mma:-Chop([seq](seq(evalhf(subs(y = log10(rand()), expr[i] - expr[j])), j = 1 .. numelems(expr)), i = 1 .. numelems(expr)), 2^(-26));
        [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]
However, the desired approach is simplifying them symbolically. Is there a way to do so in Maple?
Hi, I'm trying to add the display of graphs G1, G2, and G3 (representing the intersections -AnimCompl file-) to my three animations (G5Ex2-file). I've tried using the background option and the display command, but without success. Thank you for your help.
AnimCompl.mw
G5Ex2.mw
I want to put one option of tetrahedron SABC with AB=c, BC=a, AC=b, SA=m, SB=n, SC=p. I tried
A := [0, 0, 0];
B := [c, 0, 0];
C := [(-a^2 + b^2 + c^2)/(2*c), sqrt((a + b - c)*(a - b + c)*(-a + b + c)*(a + b + c))/(2*c), 0];
S := [x, y, z];
solve([distance(S, A) = m, distance(S, B) = n, distance(S, C) = p], [x, y, z]);
I got warning, solutions may have been lost. How can I solve that system of equations?
Just need some help using URL:-Get
Get("https://sdo.gsfc.nasa.gov/assets/img/browse/2023/05/05/20230505 _184918_512_0304.jpg")
I'm sure there are some tags to use but not sure how.  The site does show a script on best practices, but at the moment don't know how to apply them.  Can anyone offer some help?
i want to plot form 15 to 0 and 5 to 1.....but my plot shows only increasing order..how can i change it?
Download plot.mw
Is there a way to suppress dependencies of a all functions appearing in a worksheet without having to do suppress([each function])?
out_parameter_for_Sample(_)_and_rtables.mw
When I generate sample data using a random variable, a normal distribution and the Sample command, I want to see the sample and the values used to randomly evaluate the distribution which generates said sample. The Maple help sheets say you can so this with the out parameter in the Sample command. I try several different calls and hoped the rtable is filled on execution. As seen below, the execution fails. Am a specifying the rtable incorrectly? See attached Maple sheet.
with(Statistics)
with(LinearAlgebra)
When I generate sample data using a random variable, a normal distribution and the Sample commands, I want to see the sample and the values used to randomly evaluate the distribution. The Maple help sheets say you can so this with the out parameter in the Sample command.
From the help, we are required to specify a float rtable, that will be filled when the Sample command is succesfully executed.
Define a random variable.
X := RandomVariable(Normal(0, 1))
_R
Sample that random variable. We sample it 10 times and look at the output.
A := Sample(X, 10)
Vector[row](%id = 36893491057099280004)
The float rtable is defined with the sample number of elements as will be sampled.
tab1 := rtable(1 .. 10, datatype = float)
Array(%id = 36893491057099270012)
tab2 := convert(rtable(1 .. 10, datatype = float), list)
[HFloat(0.0), HFloat(0.0), HFloat(0.0), HFloat(0.0), HFloat(0.0), HFloat(0.0), HFloat(0.0), HFloat(0.0), HFloat(0.0), HFloat(0.0)]
Now I try several different calls and hope the rtable is filled on execution.
A := Sample(X, 10, out)
Error, invalid input: no implementation of Statistics:-Sample:-ModuleApply matches the arguments in call, 'Statistics:-Sample:-ModuleApply(X,10,out)'
A := Sample(X, 10, out = tab1)
Error, invalid input: no implementation of Statistics:-Sample:-ModuleApply matches the arguments in call, 'Statistics:-Sample:-ModuleApply(X,10,out = tab1)'
A := Sample(X, 10, out = tab2)
Error, invalid input: no implementation of Statistics:-Sample:-ModuleApply matches the arguments in call, 'Statistics:-Sample:-ModuleApply(X,10,out = tab2)'
A := Sample(X, 10, out = true)
Error, invalid input: no implementation of Statistics:-Sample:-ModuleApply matches the arguments in call, 'Statistics:-Sample:-ModuleApply(X,10,out = true)'
As seen above, the execution fails. Am a specifying the rtable incorrectly?
Download out_parameter_for_Sample(_)_and_rtables.mw
I followed the code on the website https://de.maplesoft.com/support/help/maple/view.aspx?path=updates/Maple18/GraphTheory to convert a graph to LaTeX code. However, after compiling with pdflatex, I found that some edges of the graph are jagged.
with(GraphTheory):
with(SpecialGraphs):
S:=SoccerBallGraph():
Latex(S,FileTools:-JoinPath([currentdir(), "soccer.tex"]),300,300,true)
soccer.pdf
I suspect it's because of the converted LaTeX code.
PS: The PDF conversion issue from last time still remains unsolved in Maple 2023; see
https://www.mapleprimes.com/questions/236142-How-To-Remove-The-Mosaic-Of-Vertices.
How to rectify this Error,in RK Method.Error, (in dsolve/numeric/bvp/convertsys) too few boundary conditions: expected 3, got 2.
I cound't plot p5,p6,p7.
If RK Method is suitable for this or not please tell the suitable numerical method code for this.Help me
IP-TEMP.mw
The example worksheet uses table to determine the covering relations in a POSET. This is old (Maple 11 and earlier code) that I have been trying to update into a package to explore calculations in an algebraic structure.  The example procedure seems to work well, but because of problems with similar procedures elsewhere, I have some concerns about the validity of using tables in this fashion. Specifically, this procedure initializes a table, then proceeds to modify the table entries, and then reformats the sequences into sets.  I have not been able to find documentation for modifying entries in tables after they have been defined. The documentation for tables only covers adding entries, removing entries, but not modifying entries.
Is modifying tables as my  procedure does an undocumented feature?
In addition, the documentation does not explain how to clear a table. It only describes how to clear a table entry. Older code sometimes purported to clear a table by assigning its name (with uneval quotes) to itself, but this does not seem to work.
exampletableoperations.mw
Hi to All! I have a big expression including 10 constant parameters (k_1, k_2, k_3, omega_1, omega_2, omega_3, a_3, b_2, c_0, c_2) to be solved for a_3, b_2, c_0, c_2. I wonder if there is any relation between the constants a_3, b_2, c_0, c_2 not depending on (k_1, k_2, k_3, omega_1, omega_2, omega_3) satisfying this big expression e.g. a_3=2, b_2=c_0/5, c_2 free.
I also tried fsolve but I could not get an answer.
Thank you in advance.
question1.mw
In accordance with this statement obtained by Чебышёв (1853), each of
simplify(int(x^(1/2)*(x^2 + 1)^(-3/4), x), symbolic);
simplify(int((x^(1)*(1 - x^2))^(1/3), x), symnolic);
simplify(int(x^(-1)*(x^6 + 1)^(-1/6), x), symnolic);
simplify(int(x^(17/2)*(x^2 + 1)^(1/4), x), symnolic);
can be reduced to an integral of rational functions, which can be expressed in terms of elementary functions. But it appears that Maple 2023.0 is still unable to completely calculate them. For instance:
interface(version)
timelimit(0.1e4, `assuming`([simplify(int(x^(1/2)/(x^2+1)^(3/4), x))], [x > 0]))
(2/3)*x^(3/2)*hypergeom([3/4, 3/4], [7/4], -x^2)
timelimit(0.1e4, `assuming`([simplify(int((x*(-x^2+1))^(1/3), x))], [`or`(`and`(x <= 1, x >= 0), x <= -1)]))
(3/4)*x^(4/3)*hypergeom([-1/3, 2/3], [5/3], x^2)
timelimit(0.1e4, `assuming`([simplify(int(1/(x*(x^6+1)^(1/6)), x))], [x <> 0]))
-(1/36)*x^6*hypergeom([1, 1, 7/6], [2, 2], -x^6)-(1/12)*Pi*3^(1/2)-(1/3)*ln(2)-(1/4)*ln(3)+ln(x)
timelimit(0.1e4, `assuming`([simplify(int(x^(17/2)*(x^2+1)^(1/4), x))], [x > 0]))
(1/81920)*(8192*x^10*(x^2+1)^(1/4)+512*x^8*(x^2+1)^(1/4)-640*x^6*(x^2+1)^(1/4)+880*x^4*(x^2+1)^(1/4)-1155*ln(2*RootOf(_Z^2+1)*x^(1/2)*(x^2+1)^(3/4)-2*RootOf(_Z^2+1)*x^(3/2)*(x^2+1)^(1/4)+2*(x^2+1)^(1/2)*x-2*x^2-1)*x^(1/2)*RootOf(_Z^2+1)-1540*x^2*(x^2+1)^(1/4)-1155*x^(1/2)*ln(-2*x^(1/2)*(x^2+1)^(3/4)-2*x^(3/2)*(x^2+1)^(1/4)+2*(x^2+1)^(1/2)*x+2*x^2+1))/x^(1/2)
gc()
Download Chebyshev_theorem_on_the_integration_of_binomial_differentials.mw
However, closed-form (and readable) solutions in elementary forms exist (cf. Regression reports for Computer Algebra Independent Integration Tests. Summer 2022 version (12000.org)); in fact, Mathematica returns:
So, why can't Maple find these compact antiderivatives (expressed by elementary functions) directly here? In other words, is there a way to resolve them in Maple without applying some change of the variable to these indefinite integrals manually?
First 206 207 208 209 210 211 212 Last Page 208 of 2431
