I would like to compute Hardy−Littlewood maximal function : we use polar coordinate for a radial function  and then evalaute integral with respect the radius r
Hardy_maximal_function.mw
Thank you for your help
u := c1*BesselK(0, alpha1*r) + c2*BesselI(0, alpha1*r) + c3*BesselK(0, alpha2*r) + c4*BesselI(0, alpha2*r) - A1*k^2*(k^2 - (-alpha^2*j*s + 4*c*s)/c)*BesselK(0, k*r)/((-alpha1^2 + k^2)*(-alpha2^2 + k^2)) - B1*k^2*(k^2 - (-alpha^2*j*s + 4*c*s)/c)*BesselI(0, k*r)/((-alpha1^2 + k^2)*(-alpha2^2 + k^2)) + ur*(-alpha^2*j*s + 4*c*s)/(c*(1 + c));
w := (-1 - c)/(2*s*(4.*c - alpha^2*j))*collect(diff(diff(r*diff(u, r), r)/r, r) + (alpha^2 - 4*c*s)*diff(u, r)/(1 + c) - A1*k^3*BesselK(1, k*r) + B1*k^3*BesselI(1, k*r), [c1, c2, c3, c4], factor);
om := (-1)/2*diff(u, r)/r;
fn1 := collect(simplify(subs(subs(r = 1, u))), [c1, c2, c3, c4], factor);
fn2 := collect(simplify(subs(subs(r = sigma, u))), [c1, c2, c3, c4], factor);
fn3 := collect(simplify(subs(r = 1, w)), [c1, c2, c3, c4], factor);
fn4 := collect(simplify(subs(r = sigma, w)), [c1, c2, c3, c4], factor);
soln := simplify(solve({fn1 = 0, fn2 = 0, fn3 = 0, fn4 = 0}, {c1, c2, c3, c4}));
I was translating some code from Mathematica to Maple. Why MmaTranslator does not know about Mathematica's CubeRoot function? This was added in 2012 (more than 11 years ago).
Is this known? How could one teach Maple's MmaTranslator to convert CubeRoot[x] to surd(x,3)? Is it possible to manually add missing translations to this package? Otherwise I would have to manually edit lots of code and do this myself each time.
with(MmaTranslator);
FromMma(`CubeRoot[9]`);
Gives CubeRoot(9) it should be surd(9, 3)
Version 2023 on windows 10
The Dominating set defination and Minimal dominating set definations given below
Code to generate the above.
A Function  F such that given the Graph G and vertex v as input the function should return me the number  of minimal dominating sets in the graph G contating the vertex v.
The logic to code seems to be above me Kind help some one please.
As manually doing is not that easy kind help.
I will surely acknowlege,
Kind help
We can read all the graphs in a file at once, or we can use an iterative approach. But can I specify a certain number of lines to read?
with(GraphTheory):
g:=ImportGraph("E:/5cc3free.txt", graph6, output=list)
The contents of 5cc3free.txt are as follows (all 5-vertex C_3 free connected graphs).  There are 6 lines.
D?{
D@s
DBw
DFw
DDW
DqK
The reason for wanting this kind of operation is that sometimes there are tens of thousands of graphs stored in a single file, and I want to read them in batches. For example, I want to extract the graph data from lines 1-2, 3-4, and 5-6 in batches. How can I accomplish this?
In the previous example, a small dataset was used for demonstration purposes. In the following example, which involves all 8-vertex connected graphs (see the attachment graph8c.txt), I want to extract the graphs from lines 200-300.
I found that readline always starts reading from the first line of a file, so the efficiency may not be very high.
For example - I have a for loop acting on a Matrix
a:=Matrix(20,20,rand(0..1.)
for i from 1 to 20 do
  for j from 1 to 20 do
    if a[i,j]<0.2 then a[i,j]:=0 end if:
Is there an equivalent sequence loop?  I tried to set up a double seq to set the values in the matrix but this fails
seq(seq(`if`(a[i,j]<0.2,a[i,j]:=0,a[i,j]),i=1..20),j=1..20)
I have list of lists I looking to Shuffle the entire List of lists in a very very non-sequencial manner everthing thing fully shuffled.
I tried but I am unable to find the right way.
Attached a code I tried
Code like below
toy_shuffle.mw
Inside a big running for loop
If a particular condition is satisfied I want loop to pause until i again press the enter key again
As if the condition is satisfied I want to note down the output results printed on screen when that condition is satisfied.
previously C I used to use like getch() for it to wait
Kind help please.
I dont want  breakpoint it will simply call the debugger so only.
H:= Fit(a*B+b*sinh(c*B), Bdata, Hdata, B)
can someone help me ? i have never used maple13 and i have to describe a code but i cant understand what this line does. can someone help me, please?!
thank u in advance.
How can I solve Einstein’s equation and calculus of the value of the K constant in Einstein's equation and the value of the tensor stress energy that fits in this equation?
QTBend.docxSqBend.mw
I m wondering if/how (i) can use the collect function twice:  collect(a, x, form, func ):
collect(a, x, form, collect(x)), but it seems I can't use a func with opt.
Can someone help please?
Merci
Hello Y'all,
I've been on this problem for a few days now and can't seem to find a solution and hope you fine people here can help me.
Is there a way to symbolically work with matrices? In detail I'm trying to calculate blocks in a block matrix equation symbolically/analytically. The first problem I had was that of course matrices dont commutate, which is solvable by just using the LinearAlgebra package and typing in
A.B instead of A*B
For now the big problem that remains is that of course in addition to that the inversion of a matrix A is not just 1/A (or \frac{1}{A} in LaTeX) but simply A^(-1). There is the MatrixInverse function but that needs a declared matrix. And since I dont have explicit matrices I can't use Matrix or the like to declare that A is a matrix. Any help here would appreciated. I tried to work with assume, but that didn't work either and I am kind of out of options (that I find on the web) right now. In essence I just want Maple to write A^(-1) and only cancel that if an A is next to it... (albeit with not just A but of course A also being setup by addition and multiplication of matrices...).
A smaller, related interest would be a general identity matrix. One that basically just fulfills A.I=I.A=A and I^(-1)=I. At least to me that seems kind of similar but I can't just define a Mtrix as being a Matrix and not having elements...
Thank you in advance and have a nice weekend y'all! :)
Hi. I want to differentiate output of pdsolve, CA(y,z) with respect to z. how can i get the result? thnx in advance.
CA0 := 0:CAi := 0.0336:L := 3:`&Gamma;_1` := 0.05:mu := 0.000894:rho := 998:Dab := 0.196e-8:
Re_1 := 4*`&Gamma;_1`*rho/mu:g := 9.8:delta := evalf(3*mu*`&Gamma;_1`/(rho^2*g))^(1/3):
Eq1 := mu*diff(uy(z), z, z) = -rho*g;
0.894e-3*(diff(diff(uy(z), z), z)) = -9780.4
Bcs := uy(delta) = 0., D[1](uy)(0) = 0.;
uy(0.2395046078e-3) = 0., (D(uy))(0) = 0.
sol:=dsolve({Bcs, Eq1}):UY:=rhs(sol);
-(2445100000/447)*z^2+35064235998909136283971/111750000000000000000000
uy_bar := rho*g*delta^2/(3*mu):
Eq2 := UY*diff(CA(y, z), y) = Dab*diff(CA(y, z), z, z);
(-(2445100000/447)*z^2+35064235998909136283971/111750000000000000000000)*(diff(CA(y, z), y)) = 0.196e-8*(diff(diff(CA(y, z), z), z))
IBC := {CA(0, z) = 0, CA(y, 0) = 0.0336, D[2](CA)(y, delta) = 0};
{CA(0, z) = 0, CA(y, 0) = 0.336e-1, (D[2](CA))(y, 0.2395046078e-3) = 0}
sol2:= pdsolve(Eq2, IBC, numeric)
_m1045849856
sol2:-value(output=listprocedure);
[y = proc () option `Copyright (c) 2000 by Waterloo Maple Inc. All rights reserved.`; evalf(args[1]) end proc, z = proc () option `Copyright (c) 2000 by Waterloo Maple Inc. All rights reserved.`; evalf(args[2]) end proc, CA(y, z) = proc () local tv, xv, solnproc, stype, ndsol, vals; option `Copyright (c) 2001 by Waterloo Maple Inc. All rights reserved.`; Digits := trunc(evalhf(Digits)); solnproc := proc (tv, xv) local INFO, errest, nd, dvars, dary, daryt, daryx, vals, msg, i, j; option `Copyright (c) 2001 by Waterloo Maple Inc. All rights reserved.`; table( [( "soln_procedures" ) = array( 1 .. 1, [( 1 ) = (36893488148465195156)  ] ) ] ) INFO := table( [( "leftwidth" ) = 1, ( "vectorhf" ) = true, ( "timeadaptive" ) = false, ( "extrabcs" ) = [0], ( "solmat_is" ) = 0, ( "spaceadaptive" ) = false, ( "pts", z ) = [0, 0.2395046078e-3], ( "linear" ) = true, ( "mixed" ) = false, ( "solvec3" ) = Vector(21, {(1) = .0, (2) = .0, (3) = .0, (4) = .0, (5) = .0, (6) = .0, (7) = .0, (8) = .0, (9) = .0, (10) = .0, (11) = .0, (12) = .0, (13) = .0, (14) = .0, (15) = .0, (16) = .0, (17) = .0, (18) = .0, (19) = .0, (20) = .0, (21) = .0}, datatype = float[8]), ( "theta" ) = 1/2, ( "solution" ) = Array(1..3, 1..21, 1..1, {(1, 1, 1) = .0, (1, 2, 1) = .0, (1, 3, 1) = .0, (1, 4, 1) = .0, (1, 5, 1) = .0, (1, 6, 1) = .0, (1, 7, 1) = .0, (1, 8, 1) = .0, (1, 9, 1) = .0, (1, 10, 1) = .0, (1, 11, 1) = .0, (1, 12, 1) = .0, (1, 13, 1) = .0, (1, 14, 1) = .0, (1, 15, 1) = .0, (1, 16, 1) = .0, (1, 17, 1) = .0, (1, 18, 1) = .0, (1, 19, 1) = .0, (1, 20, 1) = .0, (1, 21, 1) = .0, (2, 1, 1) = .0, (2, 2, 1) = .0, (2, 3, 1) = .0, (2, 4, 1) = .0, (2, 5, 1) = .0, (2, 6, 1) = .0, (2, 7, 1) = .0, (2, 8, 1) = .0, (2, 9, 1) = .0, (2, 10, 1) = .0, (2, 11, 1) = .0, (2, 12, 1) = .0, (2, 13, 1) = .0, (2, 14, 1) = .0, (2, 15, 1) = .0, (2, 16, 1) = .0, (2, 17, 1) = .0, (2, 18, 1) = .0, (2, 19, 1) = .0, (2, 20, 1) = .0, (2, 21, 1) = .0, (3, 1, 1) = .0, (3, 2, 1) = .0, (3, 3, 1) = .0, (3, 4, 1) = .0, (3, 5, 1) = .0, (3, 6, 1) = .0, (3, 7, 1) = .0, (3, 8, 1) = .0, (3, 9, 1) = .0, (3, 10, 1) = .0, (3, 11, 1) = .0, (3, 12, 1) = .0, (3, 13, 1) = .0, (3, 14, 1) = .0, (3, 15, 1) = .0, (3, 16, 1) = .0, (3, 17, 1) = .0, (3, 18, 1) = .0, (3, 19, 1) = .0, (3, 20, 1) = .0, (3, 21, 1) = .0}, datatype = float[8], order = C_order), ( "solmat_i2" ) = 0, ( "depdords" ) = [[[1, 2]]], ( "matrixproc" ) = proc (v, vp, vpp, t, x, k, h, n, mat) local _s1, _s2, _s3, xi; _s1 := -(49/50000000000)/h^2; _s2 := -(2445100000/447)/k; _s3 := (49/111750000000000000000000)*(715596653038961964979*h^2+4470000000000*k)/(k*h^2); mat[4] := 1; mat[8*n-4] := (3/2)/h; mat[8*n-6] := (1/2)/h; mat[8*n-5] := -2/h; for xi from 2 to n-1 do mat[8*xi-4] := _s2*x[xi]^2+_s3; mat[8*xi-5] := _s1; mat[8*xi-3] := _s1 end do end proc, ( "totalwidth" ) = 8, ( "solmatrix" ) = Matrix(21, 8, {(1, 1) = .0, (1, 2) = .0, (1, 3) = .0, (1, 4) = .0, (1, 5) = .0, (1, 6) = .0, (1, 7) = .0, (1, 8) = .0, (2, 1) = .0, (2, 2) = .0, (2, 3) = .0, (2, 4) = .0, (2, 5) = .0, (2, 6) = .0, (2, 7) = .0, (2, 8) = .0, (3, 1) = .0, (3, 2) = .0, (3, 3) = .0, (3, 4) = .0, (3, 5) = .0, (3, 6) = .0, (3, 7) = .0, (3, 8) = .0, (4, 1) = .0, (4, 2) = .0, (4, 3) = .0, (4, 4) = .0, (4, 5) = .0, (4, 6) = .0, (4, 7) = .0, (4, 8) = .0, (5, 1) = .0, (5, 2) = .0, (5, 3) = .0, (5, 4) = .0, (5, 5) = .0, (5, 6) = .0, (5, 7) = .0, (5, 8) = .0, (6, 1) = .0, (6, 2) = .0, (6, 3) = .0, (6, 4) = .0, (6, 5) = .0, (6, 6) = .0, (6, 7) = .0, (6, 8) = .0, (7, 1) = .0, (7, 2) = .0, (7, 3) = .0, (7, 4) = .0, (7, 5) = .0, (7, 6) = .0, (7, 7) = .0, (7, 8) = .0, (8, 1) = .0, (8, 2) = .0, (8, 3) = .0, (8, 4) = .0, (8, 5) = .0, (8, 6) = .0, (8, 7) = .0, (8, 8) = .0, (9, 1) = .0, (9, 2) = .0, (9, 3) = .0, (9, 4) = .0, (9, 5) = .0, (9, 6) = .0, (9, 7) = .0, (9, 8) = .0, (10, 1) = .0, (10, 2) = .0, (10, 3) = .0, (10, 4) = .0, (10, 5) = .0, (10, 6) = .0, (10, 7) = .0, (10, 8) = .0, (11, 1) = .0, (11, 2) = .0, (11, 3) = .0, (11, 4) = .0, (11, 5) = .0, (11, 6) = .0, (11, 7) = .0, (11, 8) = .0, (12, 1) = .0, (12, 2) = .0, (12, 3) = .0, (12, 4) = .0, (12, 5) = .0, (12, 6) = .0, (12, 7) = .0, (12, 8) = .0, (13, 1) = .0, (13, 2) = .0, (13, 3) = .0, (13, 4) = .0, (13, 5) = .0, (13, 6) = .0, (13, 7) = .0, (13, 8) = .0, (14, 1) = .0, (14, 2) = .0, (14, 3) = .0, (14, 4) = .0, (14, 5) = .0, (14, 6) = .0, (14, 7) = .0, (14, 8) = .0, (15, 1) = .0, (15, 2) = .0, (15, 3) = .0, (15, 4) = .0, (15, 5) = .0, (15, 6) = .0, (15, 7) = .0, (15, 8) = .0, (16, 1) = .0, (16, 2) = .0, (16, 3) = .0, (16, 4) = .0, (16, 5) = .0, (16, 6) = .0, (16, 7) = .0, (16, 8) = .0, (17, 1) = .0, (17, 2) = .0, (17, 3) = .0, (17, 4) = .0, (17, 5) = .0, (17, 6) = .0, (17, 7) = .0, (17, 8) = .0, (18, 1) = .0, (18, 2) = .0, (18, 3) = .0, (18, 4) = .0, (18, 5) = .0, (18, 6) = .0, (18, 7) = .0, (18, 8) = .0, (19, 1) = .0, (19, 2) = .0, (19, 3) = .0, (19, 4) = .0, (19, 5) = .0, (19, 6) = .0, (19, 7) = .0, (19, 8) = .0, (20, 1) = .0, (20, 2) = .0, (20, 3) = .0, (20, 4) = .0, (20, 5) = .0, (20, 6) = .0, (20, 7) = .0, (20, 8) = .0, (21, 1) = .0, (21, 2) = .0, (21, 3) = .0, (21, 4) = .0, (21, 5) = .0, (21, 6) = .0, (21, 7) = .0, (21, 8) = .0}, datatype = float[8], order = C_order), ( "eqnords" ) = [[1, 2]], ( "multidep" ) = [false, false], ( "maxords" ) = [1, 2], ( "errorest" ) = false, ( "norigdepvars" ) = 1, ( "spacevar" ) = z, ( "eqndep" ) = [1], ( "spaceidx" ) = 2, ( "dependson" ) = [{1}], ( "bandwidth" ) = [2, 3], ( "spacestep" ) = 0.119752303900000e-4, ( "solvec5" ) = 0, ( "matrixhf" ) = true, ( "depords" ) = [[1, 2]], ( "erroraccum" ) = true, ( "depeqn" ) = [1], ( "stages" ) = 1, ( "startup_only" ) = false, ( "spacepts" ) = 21, ( "vectorproc" ) = proc (v, vp, vpp, t, x, k, h, n, vec) local _s1, _s2, _s3, _s4, xi; _s2 := (49/50000000000)/h^2; _s3 := -(2445100000/447)/k; _s4 := (35064235998909136283971/111750000000000000000000)/k; vec[1] := 0.336e-1; vec[n] := 0; for xi from 2 to n-1 do _s1 := vp[xi-1]-2*vp[xi]+vp[xi+1]; vec[xi] := _s2*_s1+(_s3*x[xi]^2+_s4)*vp[xi] end do end proc, ( "t0" ) = 0, ( "allocspace" ) = 21, ( "initialized" ) = false, ( "method" ) = theta, ( "depvars" ) = [CA], ( "BCS", 1 ) = {[[1, 0, 0], b[1, 0, 0]-0.336e-1], [[1, 1, 0.2395046078e-3], b[1, 1, 0.2395046078e-3]]}, ( "timeidx" ) = 1, ( "solmat_v" ) = Vector(168, {(1) = .0, (2) = .0, (3) = .0, (4) = .0, (5) = .0, (6) = .0, (7) = .0, (8) = .0, (9) = .0, (10) = .0, (11) = .0, (12) = .0, (13) = .0, (14) = .0, (15) = .0, (16) = .0, (17) = .0, (18) = .0, (19) = .0, (20) = .0, (21) = .0, (22) = .0, (23) = .0, (24) = .0, (25) = .0, (26) = .0, (27) = .0, (28) = .0, (29) = .0, (30) = .0, (31) = .0, (32) = .0, (33) = .0, (34) = .0, (35) = .0, (36) = .0, (37) = .0, (38) = .0, (39) = .0, (40) = .0, (41) = .0, (42) = .0, (43) = .0, (44) = .0, (45) = .0, (46) = .0, (47) = .0, (48) = .0, (49) = .0, (50) = .0, (51) = .0, (52) = .0, (53) = .0, (54) = .0, (55) = .0, (56) = .0, (57) = .0, (58) = .0, (59) = .0, (60) = .0, (61) = .0, (62) = .0, (63) = .0, (64) = .0, (65) = .0, (66) = .0, (67) = .0, (68) = .0, (69) = .0, (70) = .0, (71) = .0, (72) = .0, (73) = .0, (74) = .0, (75) = .0, (76) = .0, (77) = .0, (78) = .0, (79) = .0, (80) = .0, (81) = .0, (82) = .0, (83) = .0, (84) = .0, (85) = .0, (86) = .0, (87) = .0, (88) = .0, (89) = .0, (90) = .0, (91) = .0, (92) = .0, (93) = .0, (94) = .0, (95) = .0, (96) = .0, (97) = .0, (98) = .0, (99) = .0, (100) = .0, (101) = .0, (102) = .0, (103) = .0, (104) = .0, (105) = .0, (106) = .0, (107) = .0, (108) = .0, (109) = .0, (110) = .0, (111) = .0, (112) = .0, (113) = .0, (114) = .0, (115) = .0, (116) = .0, (117) = .0, (118) = .0, (119) = .0, (120) = .0, (121) = .0, (122) = .0, (123) = .0, (124) = .0, (125) = .0, (126) = .0, (127) = .0, (128) = .0, (129) = .0, (130) = .0, (131) = .0, (132) = .0, (133) = .0, (134) = .0, (135) = .0, (136) = .0, (137) = .0, (138) = .0, (139) = .0, (140) = .0, (141) = .0, (142) = .0, (143) = .0, (144) = .0, (145) = .0, (146) = .0, (147) = .0, (148) = .0, (149) = .0, (150) = .0, (151) = .0, (152) = .0, (153) = .0, (154) = .0, (155) = .0, (156) = .0, (157) = .0, (158) = .0, (159) = .0, (160) = .0, (161) = .0, (162) = .0, (163) = .0, (164) = .0, (165) = .0, (166) = .0, (167) = .0, (168) = .0}, datatype = float[8], order = C_order, attributes = [source_rtable = (Matrix(21, 8, {(1, 1) = .0, (1, 2) = .0, (1, 3) = .0, (1, 4) = .0, (1, 5) = .0, (1, 6) = .0, (1, 7) = .0, (1, 8) = .0, (2, 1) = .0, (2, 2) = .0, (2, 3) = .0, (2, 4) = .0, (2, 5) = .0, (2, 6) = .0, (2, 7) = .0, (2, 8) = .0, (3, 1) = .0, (3, 2) = .0, (3, 3) = .0, (3, 4) = .0, (3, 5) = .0, (3, 6) = .0, (3, 7) = .0, (3, 8) = .0, (4, 1) = .0, (4, 2) = .0, (4, 3) = .0, (4, 4) = .0, (4, 5) = .0, (4, 6) = .0, (4, 7) = .0, (4, 8) = .0, (5, 1) = .0, (5, 2) = .0, (5, 3) = .0, (5, 4) = .0, (5, 5) = .0, (5, 6) = .0, (5, 7) = .0, (5, 8) = .0, (6, 1) = .0, (6, 2) = .0, (6, 3) = .0, (6, 4) = .0, (6, 5) = .0, (6, 6) = .0, (6, 7) = .0, (6, 8) = .0, (7, 1) = .0, (7, 2) = .0, (7, 3) = .0, (7, 4) = .0, (7, 5) = .0, (7, 6) = .0, (7, 7) = .0, (7, 8) = .0, (8, 1) = .0, (8, 2) = .0, (8, 3) = .0, (8, 4) = .0, (8, 5) = .0, (8, 6) = .0, (8, 7) = .0, (8, 8) = .0, (9, 1) = .0, (9, 2) = .0, (9, 3) = .0, (9, 4) = .0, (9, 5) = .0, (9, 6) = .0, (9, 7) = .0, (9, 8) = .0, (10, 1) = .0, (10, 2) = .0, (10, 3) = .0, (10, 4) = .0, (10, 5) = .0, (10, 6) = .0, (10, 7) = .0, (10, 8) = .0, (11, 1) = .0, (11, 2) = .0, (11, 3) = .0, (11, 4) = .0, (11, 5) = .0, (11, 6) = .0, (11, 7) = .0, (11, 8) = .0, (12, 1) = .0, (12, 2) = .0, (12, 3) = .0, (12, 4) = .0, (12, 5) = .0, (12, 6) = .0, (12, 7) = .0, (12, 8) = .0, (13, 1) = .0, (13, 2) = .0, (13, 3) = .0, (13, 4) = .0, (13, 5) = .0, (13, 6) = .0, (13, 7) = .0, (13, 8) = .0, (14, 1) = .0, (14, 2) = .0, (14, 3) = .0, (14, 4) = .0, (14, 5) = .0, (14, 6) = .0, (14, 7) = .0, (14, 8) = .0, (15, 1) = .0, (15, 2) = .0, (15, 3) = .0, (15, 4) = .0, (15, 5) = .0, (15, 6) = .0, (15, 7) = .0, (15, 8) = .0, (16, 1) = .0, (16, 2) = .0, (16, 3) = .0, (16, 4) = .0, (16, 5) = .0, (16, 6) = .0, (16, 7) = .0, (16, 8) = .0, (17, 1) = .0, (17, 2) = .0, (17, 3) = .0, (17, 4) = .0, (17, 5) = .0, (17, 6) = .0, (17, 7) = .0, (17, 8) = .0, (18, 1) = .0, (18, 2) = .0, (18, 3) = .0, (18, 4) = .0, (18, 5) = .0, (18, 6) = .0, (18, 7) = .0, (18, 8) = .0, (19, 1) = .0, (19, 2) = .0, (19, 3) = .0, (19, 4) = .0, (19, 5) = .0, (19, 6) = .0, (19, 7) = .0, (19, 8) = .0, (20, 1) = .0, (20, 2) = .0, (20, 3) = .0, (20, 4) = .0, (20, 5) = .0, (20, 6) = .0, (20, 7) = .0, (20, 8) = .0, (21, 1) = .0, (21, 2) = .0, (21, 3) = .0, (21, 4) = .0, (21, 5) = .0, (21, 6) = .0, (21, 7) = .0, (21, 8) = .0}, datatype = float[8], order = C_order))]), ( "depshift" ) = [1], ( "PDEs" ) = [(-(2445100000/447)*z^2+35064235998909136283971/111750000000000000000000)*(diff(CA(y, z), y))-(49/25000000000)*(diff(diff(CA(y, z), z), z))], ( "periodic" ) = false, ( "soltimes" ) = Vector(3, {(1) = .0, (2) = .0, (3) = .0}, datatype = float[8]), ( "adjusted" ) = false, ( "timevar" ) = y, ( "banded" ) = true, ( "explicit" ) = false, ( "solspace" ) = Vector(21, {(1) = .0, (2) = .0, (3) = .0, (4) = .0, (5) = .0, (6) = .0, (7) = .0, (8) = .0, (9) = .0, (10) = .0, (11) = .0, (12) = .0, (13) = .0, (14) = .0, (15) = .0, (16) = .0, (17) = .0, (18) = .0, (19) = .0, (20) = .0, (21) = 0.2395046078e-3}, datatype = float[8]), ( "ICS" ) = [0], ( "inputargs" ) = [(-(2445100000/447)*z^2+35064235998909136283971/111750000000000000000000)*(diff(CA(y, z), y)) = 0.196e-8*(diff(diff(CA(y, z), z), z)), {CA(0, z) = 0, CA(y, 0) = 0.336e-1, (D[2](CA))(y, 0.2395046078e-3) = 0}], ( "solmat_i1" ) = 0, ( "fdepvars" ) = [CA(y, z)], ( "solvec2" ) = Vector(21, {(1) = .0, (2) = .0, (3) = .0, (4) = .0, (5) = .0, (6) = .0, (7) = .0, (8) = .0, (9) = .0, (10) = .0, (11) = .0, (12) = .0, (13) = .0, (14) = .0, (15) = .0, (16) = .0, (17) = .0, (18) = .0, (19) = .0, (20) = .0, (21) = .0}, datatype = float[8]), ( "minspcpoints" ) = 4, ( "IBC" ) = b, ( "indepvars" ) = [y, z], ( "intspace" ) = Matrix(21, 1, {(1, 1) = .0, (2, 1) = .0, (3, 1) = .0, (4, 1) = .0, (5, 1) = .0, (6, 1) = .0, (7, 1) = .0, (8, 1) = .0, (9, 1) = .0, (10, 1) = .0, (11, 1) = .0, (12, 1) = .0, (13, 1) = .0, (14, 1) = .0, (15, 1) = .0, (16, 1) = .0, (17, 1) = .0, (18, 1) = .0, (19, 1) = .0, (20, 1) = .0, (21, 1) = .0}, datatype = float[8], order = C_order), ( "rightwidth" ) = 0, ( "timestep" ) = 0.119752303900000e-4, ( "solvec1" ) = Vector(21, {(1) = .0, (2) = .0, (3) = .0, (4) = .0, (5) = .0, (6) = .0, (7) = .0, (8) = .0, (9) = .0, (10) = .0, (11) = .0, (12) = .0, (13) = .0, (14) = .0, (15) = .0, (16) = .0, (17) = .0, (18) = .0, (19) = .0, (20) = .0, (21) = .0}, datatype = float[8]), ( "solvec4" ) = 0, ( "solmat_ne" ) = 0, ( "autonomous" ) = true ] ); if xv = "left" then return INFO["solspace"][1] elif xv = "right" then return INFO["solspace"][INFO["spacepts"]] elif tv = "start" then return INFO["t0"] elif not (type(tv, 'numeric') and type(xv, 'numeric')) then error "non-numeric input" end if; if xv < INFO["solspace"][1] or INFO["solspace"][INFO["spacepts"]] < xv then error "requested %1 value must be in the range %2..%3", INFO["spacevar"], INFO["solspace"][1], INFO["solspace"][INFO["spacepts"]] end if; dary := Vector(3, {(1) = .0, (2) = .0, (3) = .0}, datatype = float[8]); daryt := 0; daryx := 0; dvars := []; errest := false; nd := nops(INFO["depvars"]); if dary[nd+1] <> tv then try `pdsolve/numeric/evolve_solution`(INFO, tv) catch: msg := StringTools:-FormatMessage(lastexception[2 .. -1]); if tv < INFO["t0"] then error cat("unable to compute solution for %1<%2:
", msg), INFO["timevar"], INFO["failtime"] else error cat("unable to compute solution for %1>%2:
", msg), INFO["timevar"], INFO["failtime"] end if end try end if; if dary[nd+1] <> tv or dary[nd+2] <> xv then `pdsolve/interp2dto0d`(3, INFO["soltimes"], INFO["spacepts"], INFO["solspace"], nops(INFO["depvars"]), INFO["solution"], true, tv, xv, dary); if errest then `pdsolve/interp2dto0d`(3, INFO["soltimes"], INFO["spacepts"], INFO["err_t"], nops(INFO["depvars"]), INFO["solution"], true, tv, xv, daryt); `pdsolve/interp2dto0d`(3, INFO["soltimes"], INFO["spacepts"], INFO["err_x"], nops(INFO["depvars"]), INFO["solution"], true, tv, xv, daryx) end if end if; dary[nd+1] := tv; dary[nd+2] := xv; if dvars = [] then [seq(dary[i], i = 1 .. INFO["norigdepvars"])] else vals := NULL; for i to nops(dvars) do j := eval(dvars[i]); try if errest then vals := vals, evalhf(j(tv, xv, dary, daryt, daryx)) else vals := vals, evalhf(j(tv, xv, dary)) end if catch: userinfo(5, `pdsolve/numeric`, `evalhf failure`); try if errest then vals := vals, j(tv, xv, dary, daryt, daryx) else vals := vals, j(tv, xv, dary) end if catch: vals := vals, undefined end try end try end do; [vals] end if end proc; stype := "1st"; if nargs = 1 then if args[1] = "left" then return solnproc(0, "left") elif args[1] = "right" then return solnproc(0, "right") elif args[1] = "start" then return solnproc("start", 0) else error "too few arguments to solution procedure" end if elif nargs = 2 then if stype = "1st" then tv := evalf(args[1]); xv := evalf(args[2]) else tv := evalf(args[2]); xv := evalf(args[1]) end if; if not (type(tv, 'numeric') and type(xv, 'numeric')) then if procname <> unknown then return ('procname')(args[1 .. nargs]) else ndsol := pointto(solnproc("soln_procedures")[1]); return ('ndsol')(args[1 .. nargs]) end if end if else error "incorrect arguments to solution procedure" end if; vals := solnproc(tv, xv); vals[1] end proc]
U:= subs(sol2:-value(output=listprocedure), CA(y, z));
proc () local tv, xv, solnproc, stype, ndsol, vals; option `Copyright (c) 2001 by Waterloo Maple Inc. All rights reserved.`; Digits := trunc(evalhf(Digits)); solnproc := proc (tv, xv) local INFO, errest, nd, dvars, dary, daryt, daryx, vals, msg, i, j; option `Copyright (c) 2001 by Waterloo Maple Inc. All rights reserved.`; table( [( "soln_procedures" ) = array( 1 .. 1, [( 1 ) = (36893488148465189476)  ] ) ] ) INFO := table( [( "leftwidth" ) = 1, ( "vectorhf" ) = true, ( "timeadaptive" ) = false, ( "extrabcs" ) = [0], ( "solmat_is" ) = 0, ( "spaceadaptive" ) = false, ( "pts", z ) = [0, 0.2395046078e-3], ( "linear" ) = true, ( "mixed" ) = false, ( "solvec3" ) = Vector(21, {(1) = .0, (2) = .0, (3) = .0, (4) = .0, (5) = .0, (6) = .0, (7) = .0, (8) = .0, (9) = .0, (10) = .0, (11) = .0, (12) = .0, (13) = .0, (14) = .0, (15) = .0, (16) = .0, (17) = .0, (18) = .0, (19) = .0, (20) = .0, (21) = .0}, datatype = float[8]), ( "theta" ) = 1/2, ( "solution" ) = Array(1..3, 1..21, 1..1, {(1, 1, 1) = .0, (1, 2, 1) = .0, (1, 3, 1) = .0, (1, 4, 1) = .0, (1, 5, 1) = .0, (1, 6, 1) = .0, (1, 7, 1) = .0, (1, 8, 1) = .0, (1, 9, 1) = .0, (1, 10, 1) = .0, (1, 11, 1) = .0, (1, 12, 1) = .0, (1, 13, 1) = .0, (1, 14, 1) = .0, (1, 15, 1) = .0, (1, 16, 1) = .0, (1, 17, 1) = .0, (1, 18, 1) = .0, (1, 19, 1) = .0, (1, 20, 1) = .0, (1, 21, 1) = .0, (2, 1, 1) = .0, (2, 2, 1) = .0, (2, 3, 1) = .0, (2, 4, 1) = .0, (2, 5, 1) = .0, (2, 6, 1) = .0, (2, 7, 1) = .0, (2, 8, 1) = .0, (2, 9, 1) = .0, (2, 10, 1) = .0, (2, 11, 1) = .0, (2, 12, 1) = .0, (2, 13, 1) = .0, (2, 14, 1) = .0, (2, 15, 1) = .0, (2, 16, 1) = .0, (2, 17, 1) = .0, (2, 18, 1) = .0, (2, 19, 1) = .0, (2, 20, 1) = .0, (2, 21, 1) = .0, (3, 1, 1) = .0, (3, 2, 1) = .0, (3, 3, 1) = .0, (3, 4, 1) = .0, (3, 5, 1) = .0, (3, 6, 1) = .0, (3, 7, 1) = .0, (3, 8, 1) = .0, (3, 9, 1) = .0, (3, 10, 1) = .0, (3, 11, 1) = .0, (3, 12, 1) = .0, (3, 13, 1) = .0, (3, 14, 1) = .0, (3, 15, 1) = .0, (3, 16, 1) = .0, (3, 17, 1) = .0, (3, 18, 1) = .0, (3, 19, 1) = .0, (3, 20, 1) = .0, (3, 21, 1) = .0}, datatype = float[8], order = C_order), ( "solmat_i2" ) = 0, ( "depdords" ) = [[[1, 2]]], ( "matrixproc" ) = proc (v, vp, vpp, t, x, k, h, n, mat) local _s1, _s2, _s3, xi; _s1 := -(49/50000000000)/h^2; _s2 := -(2445100000/447)/k; _s3 := (49/111750000000000000000000)*(715596653038961964979*h^2+4470000000000*k)/(k*h^2); mat[4] := 1; mat[8*n-4] := (3/2)/h; mat[8*n-6] := (1/2)/h; mat[8*n-5] := -2/h; for xi from 2 to n-1 do mat[8*xi-4] := _s2*x[xi]^2+_s3; mat[8*xi-5] := _s1; mat[8*xi-3] := _s1 end do end proc, ( "totalwidth" ) = 8, ( "solmatrix" ) = Matrix(21, 8, {(1, 1) = .0, (1, 2) = .0, (1, 3) = .0, (1, 4) = .0, (1, 5) = .0, (1, 6) = .0, (1, 7) = .0, (1, 8) = .0, (2, 1) = .0, (2, 2) = .0, (2, 3) = .0, (2, 4) = .0, (2, 5) = .0, (2, 6) = .0, (2, 7) = .0, (2, 8) = .0, (3, 1) = .0, (3, 2) = .0, (3, 3) = .0, (3, 4) = .0, (3, 5) = .0, (3, 6) = .0, (3, 7) = .0, (3, 8) = .0, (4, 1) = .0, (4, 2) = .0, (4, 3) = .0, (4, 4) = .0, (4, 5) = .0, (4, 6) = .0, (4, 7) = .0, (4, 8) = .0, (5, 1) = .0, (5, 2) = .0, (5, 3) = .0, (5, 4) = .0, (5, 5) = .0, (5, 6) = .0, (5, 7) = .0, (5, 8) = .0, (6, 1) = .0, (6, 2) = .0, (6, 3) = .0, (6, 4) = .0, (6, 5) = .0, (6, 6) = .0, (6, 7) = .0, (6, 8) = .0, (7, 1) = .0, (7, 2) = .0, (7, 3) = .0, (7, 4) = .0, (7, 5) = .0, (7, 6) = .0, (7, 7) = .0, (7, 8) = .0, (8, 1) = .0, (8, 2) = .0, (8, 3) = .0, (8, 4) = .0, (8, 5) = .0, (8, 6) = .0, (8, 7) = .0, (8, 8) = .0, (9, 1) = .0, (9, 2) = .0, (9, 3) = .0, (9, 4) = .0, (9, 5) = .0, (9, 6) = .0, (9, 7) = .0, (9, 8) = .0, (10, 1) = .0, (10, 2) = .0, (10, 3) = .0, (10, 4) = .0, (10, 5) = .0, (10, 6) = .0, (10, 7) = .0, (10, 8) = .0, (11, 1) = .0, (11, 2) = .0, (11, 3) = .0, (11, 4) = .0, (11, 5) = .0, (11, 6) = .0, (11, 7) = .0, (11, 8) = .0, (12, 1) = .0, (12, 2) = .0, (12, 3) = .0, (12, 4) = .0, (12, 5) = .0, (12, 6) = .0, (12, 7) = .0, (12, 8) = .0, (13, 1) = .0, (13, 2) = .0, (13, 3) = .0, (13, 4) = .0, (13, 5) = .0, (13, 6) = .0, (13, 7) = .0, (13, 8) = .0, (14, 1) = .0, (14, 2) = .0, (14, 3) = .0, (14, 4) = .0, (14, 5) = .0, (14, 6) = .0, (14, 7) = .0, (14, 8) = .0, (15, 1) = .0, (15, 2) = .0, (15, 3) = .0, (15, 4) = .0, (15, 5) = .0, (15, 6) = .0, (15, 7) = .0, (15, 8) = .0, (16, 1) = .0, (16, 2) = .0, (16, 3) = .0, (16, 4) = .0, (16, 5) = .0, (16, 6) = .0, (16, 7) = .0, (16, 8) = .0, (17, 1) = .0, (17, 2) = .0, (17, 3) = .0, (17, 4) = .0, (17, 5) = .0, (17, 6) = .0, (17, 7) = .0, (17, 8) = .0, (18, 1) = .0, (18, 2) = .0, (18, 3) = .0, (18, 4) = .0, (18, 5) = .0, (18, 6) = .0, (18, 7) = .0, (18, 8) = .0, (19, 1) = .0, (19, 2) = .0, (19, 3) = .0, (19, 4) = .0, (19, 5) = .0, (19, 6) = .0, (19, 7) = .0, (19, 8) = .0, (20, 1) = .0, (20, 2) = .0, (20, 3) = .0, (20, 4) = .0, (20, 5) = .0, (20, 6) = .0, (20, 7) = .0, (20, 8) = .0, (21, 1) = .0, (21, 2) = .0, (21, 3) = .0, (21, 4) = .0, (21, 5) = .0, (21, 6) = .0, (21, 7) = .0, (21, 8) = .0}, datatype = float[8], order = C_order), ( "eqnords" ) = [[1, 2]], ( "multidep" ) = [false, false], ( "maxords" ) = [1, 2], ( "errorest" ) = false, ( "norigdepvars" ) = 1, ( "spacevar" ) = z, ( "eqndep" ) = [1], ( "spaceidx" ) = 2, ( "dependson" ) = [{1}], ( "bandwidth" ) = [2, 3], ( "spacestep" ) = 0.119752303900000e-4, ( "solvec5" ) = 0, ( "matrixhf" ) = true, ( "depords" ) = [[1, 2]], ( "erroraccum" ) = true, ( "depeqn" ) = [1], ( "stages" ) = 1, ( "startup_only" ) = false, ( "spacepts" ) = 21, ( "vectorproc" ) = proc (v, vp, vpp, t, x, k, h, n, vec) local _s1, _s2, _s3, _s4, xi; _s2 := (49/50000000000)/h^2; _s3 := -(2445100000/447)/k; _s4 := (35064235998909136283971/111750000000000000000000)/k; vec[1] := 0.336e-1; vec[n] := 0; for xi from 2 to n-1 do _s1 := vp[xi-1]-2*vp[xi]+vp[xi+1]; vec[xi] := _s2*_s1+(_s3*x[xi]^2+_s4)*vp[xi] end do end proc, ( "t0" ) = 0, ( "allocspace" ) = 21, ( "initialized" ) = false, ( "method" ) = theta, ( "depvars" ) = [CA], ( "BCS", 1 ) = {[[1, 0, 0], b[1, 0, 0]-0.336e-1], [[1, 1, 0.2395046078e-3], b[1, 1, 0.2395046078e-3]]}, ( "timeidx" ) = 1, ( "solmat_v" ) = Vector(168, {(1) = .0, (2) = .0, (3) = .0, (4) = .0, (5) = .0, (6) = .0, (7) = .0, (8) = .0, (9) = .0, (10) = .0, (11) = .0, (12) = .0, (13) = .0, (14) = .0, (15) = .0, (16) = .0, (17) = .0, (18) = .0, (19) = .0, (20) = .0, (21) = .0, (22) = .0, (23) = .0, (24) = .0, (25) = .0, (26) = .0, (27) = .0, (28) = .0, (29) = .0, (30) = .0, (31) = .0, (32) = .0, (33) = .0, (34) = .0, (35) = .0, (36) = .0, (37) = .0, (38) = .0, (39) = .0, (40) = .0, (41) = .0, (42) = .0, (43) = .0, (44) = .0, (45) = .0, (46) = .0, (47) = .0, (48) = .0, (49) = .0, (50) = .0, (51) = .0, (52) = .0, (53) = .0, (54) = .0, (55) = .0, (56) = .0, (57) = .0, (58) = .0, (59) = .0, (60) = .0, (61) = .0, (62) = .0, (63) = .0, (64) = .0, (65) = .0, (66) = .0, (67) = .0, (68) = .0, (69) = .0, (70) = .0, (71) = .0, (72) = .0, (73) = .0, (74) = .0, (75) = .0, (76) = .0, (77) = .0, (78) = .0, (79) = .0, (80) = .0, (81) = .0, (82) = .0, (83) = .0, (84) = .0, (85) = .0, (86) = .0, (87) = .0, (88) = .0, (89) = .0, (90) = .0, (91) = .0, (92) = .0, (93) = .0, (94) = .0, (95) = .0, (96) = .0, (97) = .0, (98) = .0, (99) = .0, (100) = .0, (101) = .0, (102) = .0, (103) = .0, (104) = .0, (105) = .0, (106) = .0, (107) = .0, (108) = .0, (109) = .0, (110) = .0, (111) = .0, (112) = .0, (113) = .0, (114) = .0, (115) = .0, (116) = .0, (117) = .0, (118) = .0, (119) = .0, (120) = .0, (121) = .0, (122) = .0, (123) = .0, (124) = .0, (125) = .0, (126) = .0, (127) = .0, (128) = .0, (129) = .0, (130) = .0, (131) = .0, (132) = .0, (133) = .0, (134) = .0, (135) = .0, (136) = .0, (137) = .0, (138) = .0, (139) = .0, (140) = .0, (141) = .0, (142) = .0, (143) = .0, (144) = .0, (145) = .0, (146) = .0, (147) = .0, (148) = .0, (149) = .0, (150) = .0, (151) = .0, (152) = .0, (153) = .0, (154) = .0, (155) = .0, (156) = .0, (157) = .0, (158) = .0, (159) = .0, (160) = .0, (161) = .0, (162) = .0, (163) = .0, (164) = .0, (165) = .0, (166) = .0, (167) = .0, (168) = .0}, datatype = float[8], order = C_order, attributes = [source_rtable = (Matrix(21, 8, {(1, 1) = .0, (1, 2) = .0, (1, 3) = .0, (1, 4) = .0, (1, 5) = .0, (1, 6) = .0, (1, 7) = .0, (1, 8) = .0, (2, 1) = .0, (2, 2) = .0, (2, 3) = .0, (2, 4) = .0, (2, 5) = .0, (2, 6) = .0, (2, 7) = .0, (2, 8) = .0, (3, 1) = .0, (3, 2) = .0, (3, 3) = .0, (3, 4) = .0, (3, 5) = .0, (3, 6) = .0, (3, 7) = .0, (3, 8) = .0, (4, 1) = .0, (4, 2) = .0, (4, 3) = .0, (4, 4) = .0, (4, 5) = .0, (4, 6) = .0, (4, 7) = .0, (4, 8) = .0, (5, 1) = .0, (5, 2) = .0, (5, 3) = .0, (5, 4) = .0, (5, 5) = .0, (5, 6) = .0, (5, 7) = .0, (5, 8) = .0, (6, 1) = .0, (6, 2) = .0, (6, 3) = .0, (6, 4) = .0, (6, 5) = .0, (6, 6) = .0, (6, 7) = .0, (6, 8) = .0, (7, 1) = .0, (7, 2) = .0, (7, 3) = .0, (7, 4) = .0, (7, 5) = .0, (7, 6) = .0, (7, 7) = .0, (7, 8) = .0, (8, 1) = .0, (8, 2) = .0, (8, 3) = .0, (8, 4) = .0, (8, 5) = .0, (8, 6) = .0, (8, 7) = .0, (8, 8) = .0, (9, 1) = .0, (9, 2) = .0, (9, 3) = .0, (9, 4) = .0, (9, 5) = .0, (9, 6) = .0, (9, 7) = .0, (9, 8) = .0, (10, 1) = .0, (10, 2) = .0, (10, 3) = .0, (10, 4) = .0, (10, 5) = .0, (10, 6) = .0, (10, 7) = .0, (10, 8) = .0, (11, 1) = .0, (11, 2) = .0, (11, 3) = .0, (11, 4) = .0, (11, 5) = .0, (11, 6) = .0, (11, 7) = .0, (11, 8) = .0, (12, 1) = .0, (12, 2) = .0, (12, 3) = .0, (12, 4) = .0, (12, 5) = .0, (12, 6) = .0, (12, 7) = .0, (12, 8) = .0, (13, 1) = .0, (13, 2) = .0, (13, 3) = .0, (13, 4) = .0, (13, 5) = .0, (13, 6) = .0, (13, 7) = .0, (13, 8) = .0, (14, 1) = .0, (14, 2) = .0, (14, 3) = .0, (14, 4) = .0, (14, 5) = .0, (14, 6) = .0, (14, 7) = .0, (14, 8) = .0, (15, 1) = .0, (15, 2) = .0, (15, 3) = .0, (15, 4) = .0, (15, 5) = .0, (15, 6) = .0, (15, 7) = .0, (15, 8) = .0, (16, 1) = .0, (16, 2) = .0, (16, 3) = .0, (16, 4) = .0, (16, 5) = .0, (16, 6) = .0, (16, 7) = .0, (16, 8) = .0, (17, 1) = .0, (17, 2) = .0, (17, 3) = .0, (17, 4) = .0, (17, 5) = .0, (17, 6) = .0, (17, 7) = .0, (17, 8) = .0, (18, 1) = .0, (18, 2) = .0, (18, 3) = .0, (18, 4) = .0, (18, 5) = .0, (18, 6) = .0, (18, 7) = .0, (18, 8) = .0, (19, 1) = .0, (19, 2) = .0, (19, 3) = .0, (19, 4) = .0, (19, 5) = .0, (19, 6) = .0, (19, 7) = .0, (19, 8) = .0, (20, 1) = .0, (20, 2) = .0, (20, 3) = .0, (20, 4) = .0, (20, 5) = .0, (20, 6) = .0, (20, 7) = .0, (20, 8) = .0, (21, 1) = .0, (21, 2) = .0, (21, 3) = .0, (21, 4) = .0, (21, 5) = .0, (21, 6) = .0, (21, 7) = .0, (21, 8) = .0}, datatype = float[8], order = C_order))]), ( "depshift" ) = [1], ( "PDEs" ) = [(-(2445100000/447)*z^2+35064235998909136283971/111750000000000000000000)*(diff(CA(y, z), y))-(49/25000000000)*(diff(diff(CA(y, z), z), z))], ( "periodic" ) = false, ( "soltimes" ) = Vector(3, {(1) = .0, (2) = .0, (3) = .0}, datatype = float[8]), ( "adjusted" ) = false, ( "timevar" ) = y, ( "banded" ) = true, ( "explicit" ) = false, ( "solspace" ) = Vector(21, {(1) = .0, (2) = .0, (3) = .0, (4) = .0, (5) = .0, (6) = .0, (7) = .0, (8) = .0, (9) = .0, (10) = .0, (11) = .0, (12) = .0, (13) = .0, (14) = .0, (15) = .0, (16) = .0, (17) = .0, (18) = .0, (19) = .0, (20) = .0, (21) = 0.2395046078e-3}, datatype = float[8]), ( "ICS" ) = [0], ( "inputargs" ) = [(-(2445100000/447)*z^2+35064235998909136283971/111750000000000000000000)*(diff(CA(y, z), y)) = 0.196e-8*(diff(diff(CA(y, z), z), z)), {CA(0, z) = 0, CA(y, 0) = 0.336e-1, (D[2](CA))(y, 0.2395046078e-3) = 0}], ( "solmat_i1" ) = 0, ( "fdepvars" ) = [CA(y, z)], ( "solvec2" ) = Vector(21, {(1) = .0, (2) = .0, (3) = .0, (4) = .0, (5) = .0, (6) = .0, (7) = .0, (8) = .0, (9) = .0, (10) = .0, (11) = .0, (12) = .0, (13) = .0, (14) = .0, (15) = .0, (16) = .0, (17) = .0, (18) = .0, (19) = .0, (20) = .0, (21) = .0}, datatype = float[8]), ( "minspcpoints" ) = 4, ( "IBC" ) = b, ( "indepvars" ) = [y, z], ( "intspace" ) = Matrix(21, 1, {(1, 1) = .0, (2, 1) = .0, (3, 1) = .0, (4, 1) = .0, (5, 1) = .0, (6, 1) = .0, (7, 1) = .0, (8, 1) = .0, (9, 1) = .0, (10, 1) = .0, (11, 1) = .0, (12, 1) = .0, (13, 1) = .0, (14, 1) = .0, (15, 1) = .0, (16, 1) = .0, (17, 1) = .0, (18, 1) = .0, (19, 1) = .0, (20, 1) = .0, (21, 1) = .0}, datatype = float[8], order = C_order), ( "rightwidth" ) = 0, ( "timestep" ) = 0.119752303900000e-4, ( "solvec1" ) = Vector(21, {(1) = .0, (2) = .0, (3) = .0, (4) = .0, (5) = .0, (6) = .0, (7) = .0, (8) = .0, (9) = .0, (10) = .0, (11) = .0, (12) = .0, (13) = .0, (14) = .0, (15) = .0, (16) = .0, (17) = .0, (18) = .0, (19) = .0, (20) = .0, (21) = .0}, datatype = float[8]), ( "solvec4" ) = 0, ( "solmat_ne" ) = 0, ( "autonomous" ) = true ] ); if xv = "left" then return INFO["solspace"][1] elif xv = "right" then return INFO["solspace"][INFO["spacepts"]] elif tv = "start" then return INFO["t0"] elif not (type(tv, 'numeric') and type(xv, 'numeric')) then error "non-numeric input" end if; if xv < INFO["solspace"][1] or INFO["solspace"][INFO["spacepts"]] < xv then error "requested %1 value must be in the range %2..%3", INFO["spacevar"], INFO["solspace"][1], INFO["solspace"][INFO["spacepts"]] end if; dary := Vector(3, {(1) = .0, (2) = .0, (3) = .0}, datatype = float[8]); daryt := 0; daryx := 0; dvars := []; errest := false; nd := nops(INFO["depvars"]); if dary[nd+1] <> tv then try `pdsolve/numeric/evolve_solution`(INFO, tv) catch: msg := StringTools:-FormatMessage(lastexception[2 .. -1]); if tv < INFO["t0"] then error cat("unable to compute solution for %1<%2:
U(1e-5,1e-6)
HFloat(0.02593255728999584)
CA_DZ:=diff(eval(CA(y,z), sol2:-value(output=listprocedure)),z);
Error, non-algebraic expressions cannot be differentiated
Download Hw-02-01_problem.mw
Here are three algebraic numbers: (In fact, they are solutions to some equation. See the attachment below.)
bSol := {RootOf(1216*_Z^4 + (264*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 0.2246 .. 0.2266)^8 + 408*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 0.2246 .. 0.2266)^7 - 1580*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 0.2246 .. 0.2266)^6 - 6832*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 0.2246 .. 0.2266)^5 + 3508*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 0.2246 .. 0.2266)^4 + 9944*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 0.2246 .. 0.2266)^3 + 9948*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 0.2246 .. 0.2266)^2 - 10752*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 0.2246 .. 0.2266) + 5204)*_Z^3 + (891*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 0.2246 .. 0.2266)^8 + 1652*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 0.2246 .. 0.2266)^7 - 4748*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 0.2246 .. 0.2266)^6 - 24076*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 0.2246 .. 0.2266)^5 + 5354*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 0.2246 .. 0.2266)^4 + 35356*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 0.2246 .. 0.2266)^3 + 29668*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 0.2246 .. 0.2266)^2 - 196*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 0.2246 .. 0.2266) + 3971)*_Z^2 + (506*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 0.2246 .. 0.2266)^8 + 980*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 0.2246 .. 0.2266)^7 - 2264*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 0.2246 .. 0.2266)^6 - 12420*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 0.2246 .. 0.2266)^5 + 3676*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 0.2246 .. 0.2266)^4 + 11596*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 0.2246 .. 0.2266)^3 + 33800*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 0.2246 .. 0.2266)^2 - 7772*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 0.2246 .. 0.2266) + 1210)*_Z - 473*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 0.2246 .. 0.2266)^8 - 720*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 0.2246 .. 0.2266)^7 + 2560*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 0.2246 .. 0.2266)^6 + 10960*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 0.2246 .. 0.2266)^5 - 8034*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 0.2246 .. 0.2266)^4 - 13840*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 0.2246 .. 0.2266)^3 - 9304*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 0.2246 .. 0.2266)^2 + 1104*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 0.2246 .. 0.2266) - 1133, index = real[2]), RootOf(1216*_Z^4 + (264*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 1.671 .. 1.68)^8 + 408*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 1.671 .. 1.68)^7 - 1580*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 1.671 .. 1.68)^6 - 6832*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 1.671 .. 1.68)^5 + 3508*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 1.671 .. 1.68)^4 + 9944*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 1.671 .. 1.68)^3 + 9948*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 1.671 .. 1.68)^2 - 10752*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 1.671 .. 1.68) + 5204)*_Z^3 + (891*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 1.671 .. 1.68)^8 + 1652*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 1.671 .. 1.68)^7 - 4748*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 1.671 .. 1.68)^6 - 24076*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 1.671 .. 1.68)^5 + 5354*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 1.671 .. 1.68)^4 + 35356*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 1.671 .. 1.68)^3 + 29668*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 1.671 .. 1.68)^2 - 196*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 1.671 .. 1.68) + 3971)*_Z^2 + (506*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 1.671 .. 1.68)^8 + 980*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 1.671 .. 1.68)^7 - 2264*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 1.671 .. 1.68)^6 - 12420*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 1.671 .. 1.68)^5 + 3676*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 1.671 .. 1.68)^4 + 11596*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 1.671 .. 1.68)^3 + 33800*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 1.671 .. 1.68)^2 - 7772*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 1.671 .. 1.68) + 1210)*_Z - 473*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 1.671 .. 1.68)^8 - 720*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 1.671 .. 1.68)^7 + 2560*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 1.671 .. 1.68)^6 + 10960*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 1.671 .. 1.68)^5 - 8034*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 1.671 .. 1.68)^4 - 13840*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 1.671 .. 1.68)^3 - 9304*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 1.671 .. 1.68)^2 + 1104*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 1.671 .. 1.68) - 1133, index = real[2]), RootOf(1216*_Z^4 + (264*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 2.648 .. 2.657)^8 + 408*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 2.648 .. 2.657)^7 - 1580*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 2.648 .. 2.657)^6 - 6832*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 2.648 .. 2.657)^5 + 3508*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 2.648 .. 2.657)^4 + 9944*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 2.648 .. 2.657)^3 + 9948*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 2.648 .. 2.657)^2 - 10752*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 2.648 .. 2.657) + 5204)*_Z^3 + (891*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 2.648 .. 2.657)^8 + 1652*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 2.648 .. 2.657)^7 - 4748*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 2.648 .. 2.657)^6 - 24076*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 2.648 .. 2.657)^5 + 5354*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 2.648 .. 2.657)^4 + 35356*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 2.648 .. 2.657)^3 + 29668*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 2.648 .. 2.657)^2 - 196*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 2.648 .. 2.657) + 3971)*_Z^2 + (506*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 2.648 .. 2.657)^8 + 980*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 2.648 .. 2.657)^7 - 2264*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 2.648 .. 2.657)^6 - 12420*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 2.648 .. 2.657)^5 + 3676*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 2.648 .. 2.657)^4 + 11596*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 2.648 .. 2.657)^3 + 33800*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 2.648 .. 2.657)^2 - 7772*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 2.648 .. 2.657) + 1210)*_Z - 473*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 2.648 .. 2.657)^8 - 720*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 2.648 .. 2.657)^7 + 2560*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 2.648 .. 2.657)^6 + 10960*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 2.648 .. 2.657)^5 - 8034*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 2.648 .. 2.657)^4 - 13840*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 2.648 .. 2.657)^3 - 9304*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 2.648 .. 2.657)^2 + 1104*RootOf(11*_Z^9 + 17*_Z^8 - 64*_Z^7 - 280*_Z^6 + 142*_Z^5 + 370*_Z^4 + 376*_Z^3 - 96*_Z^2 + 47*_Z - 11, 2.648 .. 2.657) - 1133, index = real[2])}:
One may check that 11_X9-47_X8+96_X7-376_X6-370_X5-142_X4+280_X3+64_X2-17_X-11 is an “annihilating” polynomial of each of them (using another computer algebra system); accordingly, the degree of the minimal polynomial cannot be greater than 9. However, Maple's output indicates that the minimal polynomial is of degree 36
alias(`~`[`=`](alpha__ || (1 .. 3), ` $`, RootOf(11*_Z^9+17*_Z^8-64*_Z^7-280*_Z^6+142*_Z^5+370*_Z^4+376*_Z^3-96*_Z^2+47*_Z-11, .2246 .. .2266), RootOf(11*_Z^9+17*_Z^8-64*_Z^7-280*_Z^6+142*_Z^5+370*_Z^4+376*_Z^3-96*_Z^2+47*_Z-11, 1.671 .. 1.68), RootOf(11*_Z^9+17*_Z^8-64*_Z^7-280*_Z^6+142*_Z^5+370*_Z^4+376*_Z^3-96*_Z^2+47*_Z-11, 2.648 .. 2.657)))
({PDETools:-Solve})({`~`[`>=`](a, b, ` $`, 0), a^5*b+4*a^4*b^2+4*a^3*b^3-7*a^4*b-6*a^2*b^3-7*a*b^4+b^5-6*a^3*b+12*a^2*b^2+4*b^4+4*a^3-6*a*b^2+4*b^3+4*a^2-7*a*b+a = 0, a <> b})
bSol := `~`[subs](%, b)
evalf[2*Digits](`~`[eval](11*_X^9-47*_X^8+96*_X^7-376*_X^6-370*_X^5-142*_X^4+280*_X^3+64*_X^2-17*_X-11, `~`[`=`](_X, bSol)))
{RootOf(1216*_Z^4+(264*alpha__1^8+408*alpha__1^7-1580*alpha__1^6-6832*alpha__1^5+3508*alpha__1^4+9944*alpha__1^3+9948*alpha__1^2-10752*alpha__1+5204)*_Z^3+(891*alpha__1^8+1652*alpha__1^7-4748*alpha__1^6-24076*alpha__1^5+5354*alpha__1^4+35356*alpha__1^3+29668*alpha__1^2-196*alpha__1+3971)*_Z^2+(506*alpha__1^8+980*alpha__1^7-2264*alpha__1^6-12420*alpha__1^5+3676*alpha__1^4+11596*alpha__1^3+33800*alpha__1^2-7772*alpha__1+1210)*_Z-473*alpha__1^8-720*alpha__1^7+2560*alpha__1^6+10960*alpha__1^5-8034*alpha__1^4-13840*alpha__1^3-9304*alpha__1^2+1104*alpha__1-1133, index = real[2]), RootOf(1216*_Z^4+(264*alpha__2^8+408*alpha__2^7-1580*alpha__2^6-6832*alpha__2^5+3508*alpha__2^4+9944*alpha__2^3+9948*alpha__2^2-10752*alpha__2+5204)*_Z^3+(891*alpha__2^8+1652*alpha__2^7-4748*alpha__2^6-24076*alpha__2^5+5354*alpha__2^4+35356*alpha__2^3+29668*alpha__2^2-196*alpha__2+3971)*_Z^2+(506*alpha__2^8+980*alpha__2^7-2264*alpha__2^6-12420*alpha__2^5+3676*alpha__2^4+11596*alpha__2^3+33800*alpha__2^2-7772*alpha__2+1210)*_Z-473*alpha__2^8-720*alpha__2^7+2560*alpha__2^6+10960*alpha__2^5-8034*alpha__2^4-13840*alpha__2^3-9304*alpha__2^2+1104*alpha__2-1133, index = real[2]), RootOf(1216*_Z^4+(264*alpha__3^8+408*alpha__3^7-1580*alpha__3^6-6832*alpha__3^5+3508*alpha__3^4+9944*alpha__3^3+9948*alpha__3^2-10752*alpha__3+5204)*_Z^3+(891*alpha__3^8+1652*alpha__3^7-4748*alpha__3^6-24076*alpha__3^5+5354*alpha__3^4+35356*alpha__3^3+29668*alpha__3^2-196*alpha__3+3971)*_Z^2+(506*alpha__3^8+980*alpha__3^7-2264*alpha__3^6-12420*alpha__3^5+3676*alpha__3^4+11596*alpha__3^3+33800*alpha__3^2-7772*alpha__3+1210)*_Z-473*alpha__3^8-720*alpha__3^7+2560*alpha__3^6+10960*alpha__3^5-8034*alpha__3^4-13840*alpha__3^3-9304*alpha__3^2+1104*alpha__3-1133, index = real[2])}
{-0.7765721e-11, -0.40e-16, -0.2e-17}
`~`[`@`(evala, Minpoly)](bSol, _X)
{-17799961-(10941904462/121)*_X+(61823634144236824/14641)*_X^9-(31748793508955524/14641)*_X^8-(101389427707536/14641)*_X^7+(2187899683524768/14641)*_X^6+(660533278629392/14641)*_X^5-(35195970681077/1331)*_X^4+(4540912173250/1331)*_X^3-(226104907168/1331)*_X^2+_X^36+(562/11)*_X^35+(1306112/1331)*_X^34-(18882494/14641)*_X^33-(1885893201/14641)*_X^32-(8021957456/14641)*_X^31+(128807680096/14641)*_X^30+(601684442192/14641)*_X^29+(136952065956/14641)*_X^28-(7313279407608/14641)*_X^27-(20755313257248/14641)*_X^26-(72279502775080/14641)*_X^25-(235147325265588/14641)*_X^24+(407012808852624/14641)*_X^23-(2003920103008/1331)*_X^22-(2647129453154576/14641)*_X^21-(5329535956015778/14641)*_X^20-(11189597881735324/14641)*_X^19+(18014890583299168/14641)*_X^18-(25692630236542548/14641)*_X^17+(57603516516708946/14641)*_X^16-(875402744452912/121)*_X^15+(36990665431348512/14641)*_X^14+(67887070781490608/14641)*_X^13+(643327218250876/1331)*_X^12-(81888059180050616/14641)*_X^11+(306280599794336/14641)*_X^10}
`~`[PolynomialTools[MinimalPolynomial]](bSol, _X)
{14641*_X^36+748022*_X^35+14367232*_X^34-18882494*_X^33-1885893201*_X^32-8021957456*_X^31+128807680096*_X^30+601684442192*_X^29+136952065956*_X^28-7313279407608*_X^27-20755313257248*_X^26-72279502775080*_X^25-235147325265588*_X^24+407012808852624*_X^23-22043121133088*_X^22-2647129453154576*_X^21-5329535956015778*_X^20-11189597881735324*_X^19+18014890583299168*_X^18-25692630236542548*_X^17+57603516516708946*_X^16-105923732078802352*_X^15+36990665431348512*_X^14+67887070781490608*_X^13+7076599400759636*_X^12-81888059180050616*_X^11+306280599794336*_X^10+61823634144236824*_X^9-31748793508955524*_X^8-101389427707536*_X^7+2187899683524768*_X^6+660533278629392*_X^5-387155677491847*_X^4+49950033905750*_X^3-2487153978848*_X^2-1323970439902*_X-260609229001}
factor({{-260609229001-1323970439902*_X+407012808852624*_X^23-22043121133088*_X^22-2647129453154576*_X^21-5329535956015778*_X^20-11189597881735324*_X^19+18014890583299168*_X^18-25692630236542548*_X^17+57603516516708946*_X^16-105923732078802352*_X^15+36990665431348512*_X^14+67887070781490608*_X^13+7076599400759636*_X^12-81888059180050616*_X^11+306280599794336*_X^10+61823634144236824*_X^9-31748793508955524*_X^8-101389427707536*_X^7+2187899683524768*_X^6+660533278629392*_X^5-387155677491847*_X^4+49950033905750*_X^3-2487153978848*_X^2+14641*_X^36+748022*_X^35+14367232*_X^34-18882494*_X^33-1885893201*_X^32-8021957456*_X^31+128807680096*_X^30+601684442192*_X^29+136952065956*_X^28-7313279407608*_X^27-20755313257248*_X^26-72279502775080*_X^25-235147325265588*_X^24}[], {-17799961-(10941904462/121)*_X+(407012808852624/14641)*_X^23-(2003920103008/1331)*_X^22-(2647129453154576/14641)*_X^21-(5329535956015778/14641)*_X^20-(11189597881735324/14641)*_X^19+(18014890583299168/14641)*_X^18-(25692630236542548/14641)*_X^17+(57603516516708946/14641)*_X^16-(875402744452912/121)*_X^15+(36990665431348512/14641)*_X^14+(67887070781490608/14641)*_X^13+(643327218250876/1331)*_X^12-(81888059180050616/14641)*_X^11+(306280599794336/14641)*_X^10+(61823634144236824/14641)*_X^9-(31748793508955524/14641)*_X^8-(101389427707536/14641)*_X^7+(2187899683524768/14641)*_X^6+(660533278629392/14641)*_X^5-(35195970681077/1331)*_X^4+(4540912173250/1331)*_X^3-(226104907168/1331)*_X^2+_X^36+(562/11)*_X^35+(1306112/1331)*_X^34-(18882494/14641)*_X^33-(1885893201/14641)*_X^32-(8021957456/14641)*_X^31+(128807680096/14641)*_X^30+(601684442192/14641)*_X^29+(136952065956/14641)*_X^28-(7313279407608/14641)*_X^27-(20755313257248/14641)*_X^26-(72279502775080/14641)*_X^25-(235147325265588/14641)*_X^24}[]})
{(11*_X^9-47*_X^8+96*_X^7-376*_X^6-370*_X^5-142*_X^4+280*_X^3+64*_X^2-17*_X-11)*(83746429305*_X-163433814*_X^23-1409885474*_X^22+7323055726*_X^21+92878340298*_X^20+291711433585*_X^19-28358008525*_X^18-1146850616945*_X^17+2003142623069*_X^16+7054039060380*_X^15+10860482240404*_X^14+4410674835220*_X^13-23715924119108*_X^12+39935154074341*_X^11-76564178781009*_X^10+246946329497683*_X^9-303627746551159*_X^8+41661161235738*_X^7+181533634595246*_X^6-146573328877410*_X^5+44279227597786*_X^4-3813039868649*_X^3+234521505317*_X^2+1331*_X^27+73689*_X^26+1609349*_X^25+4562111*_X^24+23691748091), (1/14641)*(11*_X^9-47*_X^8+96*_X^7-376*_X^6-370*_X^5-142*_X^4+280*_X^3+64*_X^2-17*_X-11)*(83746429305*_X-163433814*_X^23-1409885474*_X^22+7323055726*_X^21+92878340298*_X^20+291711433585*_X^19-28358008525*_X^18-1146850616945*_X^17+2003142623069*_X^16+7054039060380*_X^15+10860482240404*_X^14+4410674835220*_X^13-23715924119108*_X^12+39935154074341*_X^11-76564178781009*_X^10+246946329497683*_X^9-303627746551159*_X^8+41661161235738*_X^7+181533634595246*_X^6-146573328877410*_X^5+44279227597786*_X^4-3813039868649*_X^3+234521505317*_X^2+1331*_X^27+73689*_X^26+1609349*_X^25+4562111*_X^24+23691748091)}
Download minpoly.mw
Isn't the results incorrect?
First 211 212 213 214 215 216 217 Last Page 213 of 2431
