Hey Guys in the attached file below, how can i create a spatial motion (3 traditional + (1 rotational) )? i keep getting errors when i use both for my Rigid body frame. I just have to activate one of the Translational or Rotational block at same time , is there any solution here
Spatial_Motion2.msim
how to solve for lamda and r in this equtaions...please help
solve(cos(lambda[i])*cosh(lambda[i]) = 1);
evalf(%);
0.
lambda[i];
lambda[i]
r[i] := (cos(lambda[i])-cosh(lambda[i]))/(sin(lambda[i])-sinh(lambda[i]));
Download 1.mw
Is it possible to read in specific parts of a bmp image?
what is the homology matrix that plates the ABCE square on the NPCM square
I think it may bi find out with the rotation angle, the vector of translation and the homothety ratio.
with(geometry):
_EnvHorizontalName = 'x':  _EnvVerticalName = 'y':
point(A, 0, 1):
point(B, 1, 1):
point(C, 1, 0):
point(E, 0, 0):
square(Sq, [A, B, C, E]):
Phi := (1 + sqrt(5))/2:
point(N, (2 - Phi)/(Phi - 1), 1):
line(BE, [B, E]):
MakeSquare(s1, [N, C, 'diagonal']):
point(M, (3 - sqrt(5))/(2*sqrt(5) - 2), (3 - sqrt(5))/(2*sqrt(5) - 2)):
point(P, (1 + sqrt(5))/(2*sqrt(5) - 2), (3*sqrt(5) - 5)/(2*sqrt(5) - 2)):
T:=<simplify(coordinates(midpoint(O1,E,B))-coordinates(midpoint(O2,M,P)))>:
simplify(distance(O1,O2)):
line(MN,[M,N]):eq:=Equation(%,[x,y]):sol:=solve(eq,y):
Ang:=Pi/2-arctan(diff(sol,x)):
r:=simplify(distance(N,M)):
line(MP,[M,P]):eq:=Equation(%,[x,y]):subs(y=0,%):point(Q,solve(%,x),0):
line(PQ,[P,Q]):
homology(Sq1, Sq, C, Ang, 'clockwise', r):
display(draw([A(color = black, symbol = solidcircle, symbolsize = 12),
B(color = black, symbol = solidcircle, symbolsize = 12),
C(color = black, symbol = solidcircle, symbolsize = 12),
E(color = black, symbol = solidcircle, symbolsize = 12),
N(color = black, symbol = solidcircle, symbolsize = 12),
Sq(color = red, filled = true, transparency = 0.9),
BE(color = green),
PQ(color = black),
 Sq1(color = black),
s1(color = red, filled = true, transparency = 0.8)]),
textplot([[coordinates(A)[], "A"],
[coordinates(B)[], "B"],
[coordinates(E)[], "E"],
[coordinates(N)[], "N"],
[coordinates(P)[], "P"],
[coordinates(M)[], "M"],
[coordinates(Q)[], "Q"],
[coordinates(C)[], "C"]],
align = [above, right]), view = [-0.6 .. 1.5, 0 .. 1], axes = none);
Given a constant gamma, gaussian random variables S[1] and S[2], and a linear combination of gaussian random variables Omega, I need to compute Exp[ Omega | S[1], S[2] ] - (gamma/2)*Var[ Omega | S[1], S[2] ]. I am not experienced in Maple. In the attached script I include many step-by-step details on what I need to do, as well as some notes where I get stuck:
150423_OptimizationProblem.mw
It would be convenient if you could directly fix this and share the working version. Thanks!
The conditional means and variance terms are calculated according to the 2D version of the script 3_gaussian_mmcdara.mw provided by @mmcdara.
Here is a string, and I want to treat consecutive single digits as a single number and extract them. I can process it using regular expressions in Python. I'm not sure if Maple can handle it in a similar way.
import re
sstr1 = "124e34e243e45e56e76f34e45e23ea12e98e34e43"
num=re.findall(r'\d+', sstr1)
s=list(map(int, num))
print(s)
[124, 34, 243, 45, 56, 76, 34, 45, 23, 12, 98, 34, 43]
Is there an equivalent regular expression method in Maple?
As usual, I have a tricky question. There is an integral that Maple can take numerically
R0 := 1/(a-sqrt(b+c*cos(x)));
Now let's put the coefficients, e.g.
 a := 0.9; b := 4.5; c :=0.1
and take the integral from 0 to 2*Pi
R1 := evalf(int(R0, x = 0 .. 2*Pi));
Also, there is an exact analytical result that Maple gives (I give it after simplifying it to avoid division by zero for the limit x=0 and x=2*Pi)
R2:=-4*((a^2-b+c)*EllipticK(sqrt(-2*c/(b-c)))-a^2*EllipticPi(2*c/(a^2-b+c), sqrt(-2*c/(b-c))))/((a^2-b+c)*sqrt(b-c));
As it turns out, the results are completely different. In the first case -5.145818656, while for the second case -3.612771378+0.I
Moreover, If we change the coefficients to a := 0.9; b := 4.5; c := -4 then I obtain Float(undefined)+3.662506136*I and -2.362349457+3.662506117*I , respectively.
My question: how to avoid this descepancy?
A := Matrix([[1, 3, 9, 2, 3, 7, 1, 1, 5, 4, 7], [7, 5, 5, 4, 9, 3, 4, 5, 3, 5, 3], [5, 2, 1, 6, 5, 4, 2, 9, 6, 6, 6], [2, 4, 1, 9, 5, 1, 1, 2, 1, 1, 7], [1, 9, 2, 3, 2, 9, 8, 2, 2, 7, 3], [5, 5, 3, 7, 2, 1, 5, 2, 7, 8, 3], [2, 2, 1, 7, 8, 7, 8, 2, 1, 4, 5], [8, 9, 6, 4, 9, 4, 1, 5, 4, 2, 5], [5, 7, 4, 5, 3, 2, 8, 3, 6, 2, 6], [6, 7, 8, 9, 9, 9, 8, 4, 8, 9, 3]]);
Use Maple to create the vector b that is column 2 from A and the matrix C that is made from columns 1 to 1 and 3 to 11 of A (in the same order as the columns of A.
Now solve the matrix equation
Cx=b
and enter the 4th component of the unique vector solution for x in the box below.
Let P(x) a polynomial with a single indeterminate.
In Maple 2015 (please, do not consider this question if Maple >=2021 doesn't present this problemcoeffs returns the coefficients P(x) in a different in some circumstances:
m := [$1..3]:
add(m[k]*(R)^(k-1), k=1..3):
c:= coeffs(%, R, 't'): [c], [t];
                              [ 2      ]
                   [3, 2, 1], [R , R, 1]
add(m[k]*(R)^(k-1), k=1..2):
                        [1, 2], [1, R]
The order in the first case is R^2, R^1, R^0 while it is R^1, R^0 in the second one.
It's quite easy to check if P(x) is of the form a+b*R and to reverse the output of coeffs. But does it exist an option of coeffs which monitors the output order.
TIA
guys..i need help ...how to find the answer for this equation..for all value of in and b in (a and b)...for all combination of a and b
problem.mw
I don't understand why my ruled surface is not displayed with this code in my animation. Maybe there is an issue with an option? All my previous animations were displayed normally. Any ideas? Thank you
G2ExamenJuin.mw
According to this help page
the transitive reduction of graph G, is the graph with the fewest edges that still shares the same reachability as G (but might contain new edges not present in G).
However, in Maple 2023, things become strange; different branches return distinct numbers of edges:
(33 arcs or 40 arcs?)
with(GraphTheory):
showstat(TransitiveReduction, 4)
GraphTheory:-TransitiveReduction := proc(G::GRAPHLN, $)
local D, V, T, i, j, k, A, M, n, flags, B;
   4   if _EnvDisableExt <> true then
       elif D <> (':-directed') then
end proc
G__0 := Digraph({[2, 8], [3, 1], [4, 9], [5, 10], [6, 19], [7, 12], [8, 13], [9, 3], [10, 4], [10, 14], [11, 5], [11, 15], [12, 6], [12, 16], [13, 7], [13, 17], [14, 9], [15, 10], [15, 18], [16, 19], [17, 12], [17, 20], [18, 14], [19, 11], [19, 21], [20, 22], [21, 18], [22, 16], [22, 23], [23, 19]})
G__0 := `Graph 1: a directed graph with 23 vertices and 30 arc(s)`
G__1 := TransitiveReduction(G__0)
G__1 := `Graph 2: a directed graph with 23 vertices and 33 arc(s)`
_EnvDisableExt := trueG__2 := TransitiveReduction(G__0)
G__2 := `Graph 3: a directed graph with 23 vertices and 40 arc(s)`
IsIsomorphic(G__1, G__2)
Download TransReduction.mw
Any bugs?
G__0 := GraphTheory:-Digraph({[3, 1], [9, 3], [4, 9], [14, 9], [10, 4], [5, 10], [15, 10], [11, 5], [19, 11], [12, 6], [7, 12], [17, 12], [13, 7], [8, 13], [2, 8], [10, 14], [18, 14], [11, 15], [6, 19], [16, 19], [23, 19], [13, 17], [15, 18], [21, 18], [12, 16], [22, 16], [22, 23], [20, 22], [19, 21], [17, 20]}):
How to find the similarity matrix that applies A in N, B in P, C in C and B in M;
with(geometry):
#Vdot := proc(U, V) local i; add(U[i]*V[i], i = 1 .. 2); end proc
point(A, 0, 1);
point(B, 1, 1);
point(C, 1, 0);
point(E, 0, 0);
square(Sq, [A, B, C, E]);
Phi := (1 + sqrt(5))/2;
point(N, (2 - Phi)/(Phi - 1), 1);
line(BE, [B, E]);
MakeSquare(s1, [N, C, 'diagonal']);
point(M, (3 - sqrt(5))/(2*sqrt(5) - 2), (3 - sqrt(5))/(2*sqrt(5) - 2));
point(P, (1 + sqrt(5))/(2*sqrt(5) - 2), (3*sqrt(5) - 5)/(2*sqrt(5) - 2));
                               A
                               B
                               C
                               E
                               Sq
                             1   1  (1/2)
                      Phi := - + - 5
                             2   2
                               N
                               BE
                               s1
                               M
                               P
 display(draw([
N(color = black, symbol = solidcircle, symbolsize = 12 ),
Sq(color=red),BE(color=green),
s1(color = blue)]),
[coordinates(C)[], "C"]], align = [above, right]), axes = none); Thank you.
For example, I'd like to do something like this (and then plot the graph):
 # display LaTeX markup
label__1 := '"\[\cfrac{\biguplus_\LaTeX}{{\color{red}\leadsto}^\unicode{2254}}\]"':
 # display non-executable notation
label__2 := '(Product(Int(i, j), Sum(k, l)) %assuming convert(log2(1 - 'x'), confrac, subdiagonal))':
 # display graphical object
label__3 := 'plots:-display(plottools:-stellate(plottools:-icosahedron()))':
 # note that the desired one is  instead of
GraphTheory:-RelabelVertices(`some graph with 3 nodes`, [label__1, label__2, label__3]):
But unfortunately, the second argument of GraphTheory:-RelabelVertices must be of type list({indexed, integer, string, symbol}), and the GraphTheory:-SetVertexAttribute command doesn't work here. Is it possible to do so in Maple® (rather than in other mathematical softwares)?
First 213 214 215 216 217 218 219 Last Page 215 of 2431
